[GRASS-user] removing gaps between areas
Martin Landa
landa.martin at gmail.com
Sat Nov 30 09:32:50 PST 2013
after patching two vector maps I am getting small gaps between areas
(see the attached screenshot).
I found 'rmsa' tool (remove small angles between lines at nodes) of
`v.clean` as suitable for this task. Unfortunately this tool ignores
threshold value [1], after a small modification of this tool I can
remove these gaps using `rmsa` tools. I just wonder if there is a more
safe or preferable way how to remove gaps.
Thanks, Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/clean_nodes.c#L85
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131130/f2218b51/attachment-0001.png>
