[GRASS-user] GUI won't start up
Saulteau Don
sault.don at gmail.com
Tue Oct 8 22:52:09 PDT 2013
You can also check if the grassrc6 file is causing an issue.
To test, rename it and a new one will be created next time you run grass.
The grassrc6 file is usually found
in C:\Users\<username>\AppData\Roaming\GRASS6\grassrc6 (for eg, rename it
to grassrc6.old)
AppData is a hidden folder.
If grass works after renaming the file, maybe try adding the options from
the grassrc6.old file into the new file, a little by little, restarting
grass along the way till you find which options could be causing an issue.
Donovan
On Tue, Oct 8, 2013 at 5:27 PM, Anna Petrášová <kratochanna at gmail.com>wrote:
> Hi,
> On Tue, Oct 8, 2013 at 5:28 PM, Uli Strötz <ustroetz at gmail.com> wrote:
>> Hello,
>> I am trying to open the GRASS GIS 6.4.3 GUI but it doesn't start up. The
>> command line quickly shows up but closes automatically again. I uninstalled
>> and re-installed it but it didn't help. The GRASS GIS command line itself I
>> can open and it works.
>> I am on Windows 7.
>> Any ideas how I can solve that?
> when you type g.gui in the grass command line, what do you get?
> Anna
>> Thanks,
>> Uli
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131008/8f7ffdde/attachment.html>
