[GRASS-user] Wingrass Raster Layer Manager issue
Vaclav Petras
wenzeslaus at gmail.com
Thu Oct 10 13:06:04 PDT 2013
These libraries (MS runtime libraries) should be installed by GRASS
installer, however they are installed only when you request that (for
legal/licence reasons). The checkbox is at one of the installer wizard
pages (the one with installation of sample dataset).
On Thu, Oct 10, 2013 at 12:48 PM, Bulent Arikan <bulent.arikan at gmail.com>wrote:
> Hi,
> Thank you for your response and suggestions. I figured it out soon after I
> posted the question. Although GRASS launched fine, it was missing .NET
> framework. I installed v 4.5 of that and it works now!
> Thank you again!
> BÜLENT
> On Oct 10, 2013, at 7:45 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi Bülent,
> can you check the Command console tab in the Layer Manager which is the
> second item from the left at the bottom of Layer Manager window? There
> might be an error message in there. You may also check the (black) windows
> command line.
> The layer with the label "raster (double click to change properties)" is
> created immediately when you press the "Add raster map layer" button. If
> there is no text, it is a problem.
> This seems that this will be hard to reproduce, so it would be great help
> if you double check all consoles, all opened windows, try this with nightly
> build of GRASS 7, do some screenshots (1)... it's hard to say what is
> important. For now it could be enough if you just check the Command console.
> Vaclav
> (1) You may want to send the screenshots only to me, to avoid file size
> limit check in the mailing list.
> On Thu, Oct 10, 2013 at 4:04 AM, Bulent Arikan <bulent.arikan at gmail.com>
> wrote:
> > Dear List,
> > I am having trouble with the Layer Manager in winGRASS 6.4.3.1
> downloaded from (http://grass.osgeo.org/grass64/binary/mswindows/native/).
> This is a PC running Windows 7.
> > The problem is that when I want to add a raster or vector layer, that
> separate window that needs to pop up is not coming. Rather, the Layer
> Manager creates a layer with no name. I tried to use the "rename" option by
> right clicking. I types the name of the map but it dis not work. I also
> could not remove the layer.
> > I downloaded and installed the same application package on a different
> PC with the same OS and I did not have the issue. This suggests to me that
> this is an issue about the computer I am using. I have not seen anything
> like that. Am I missing an additional file? Should I download and install
> .NET Framework (although, GRASS launches fine).
> > Thank you,
> > BÜLENT
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131010/ea473476/attachment.html>
