[GRASS-user] converting LAT/LON coordinates to X/Y coordinates
Levente Juhász jlevente89 at gmail.com
Mon Oct 14 00:50:00 PDT 2013
hi,
if you're working with shapefiles (that you mentioned in your first mail)
the best solution for you is using a map reprojection. you can follow the
following steps that you can see in the wiki: [1]
[1] http://grasswiki.osgeo.org/wiki/Map_Reprojection (you'd need v.proj)
regards,
Levente
2013/10/14 Nikos Alexandris <nik at nikosalexandris.net>
> Micha Silver wrote:
> > For jobs like this you can use the cs2cs tool (part of the proj4
> package) to
> > convert coordinate pairs from one CRS to another. You can see some
> examples
> > on the wiki page [1] (Note: The coordinates below do not look like
> Lon/Lat)
> > [1]  http://trac.osgeo.org/proj/wiki/man_cs2cs
> GRASS GIS' "m.proj" is also fit for the task I think. It is charachterised
> as
> a cs2cs frontend: <http://grass.osgeo.org/grass64/manuals/m.proj.html>.
> Nikos
> [rest deleted]
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131014/149b3207/attachment.html>
