[GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
Vaclav Petras
wenzeslaus at gmail.com
Mon Oct 14 10:34:31 PDT 2013
On Mon, Oct 14, 2013 at 12:19 PM, Cesar Augusto Ramírez Franco <
caesarivs at gmail.com> wrote:
> To be able to install grass addons in 6.4.3 you need to install the
> grass-dev package with sudo apt-get install grass-dev and then issue the
> g.extension command
> Maybe, GRASS, namely g.extension, should identify the error (e.g. check
the include/Make directory) and report an error with a suggestion (if on
linux: "Check that you have package ..."). But this might be very different
for various distributions.
Probably also the package description and suggested/related packages should
provide some information.
> Regards
> 2013/10/14 Johannes Radinger <johannesradinger at gmail.com>
>> Hi all,
>> I want to install G7 and G6.4.3 as well as several add-ons on a freshly
>> installed Xubuntu (12.04) machine (Virtualbox) for testing purposes.
>> Therefore I run following commands after Xubuntu installation and update of
>> the system:
>> sudo add-apt-repository ppa:grass/grass-devel
>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> sudo apt-get update
>> sudo apt-get install grass643 grass70 grass-gui grass70-gui
>> However after successful installation I run into following two problems:
>> 1) When I try to launch G7-gui (e.g. with standard NC example dataset) I
>> get following error:
>> Launching <wxpython> GUI in the background, please wait...
>> GRASS 7.0.svn (nc_basic_spm_grass7):~ > Traceback (most recent call last):
>> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 143, in <module>
>> sys.exit(main())
>> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 136, in main
>> app = GMApp(workspaceFile)
>> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 50, in __init__
>> wx.App.__init__(self, False)
>> File
>> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
>> 7981, in __init__
>> self._BootstrapApp()
>> File
>> 7555, in _BootstrapApp
>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 84, in OnInit
>> workspace = self.workspaceFile)
>> File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py", line 108, in
>> __init__
>> self._menuTreeBuilder = LayerManagerMenuData()
>> File "/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py", line 40, in
>> __init__
>> MenuTreeModelBuilder.__init__(self, filename,
>> expandAddons=expandAddons)
>> File "/usr/lib/grass70/etc/gui/wxpython/core/menutree.py", line 69, in
>> __init__
>> xmlTree = etree.parse(filename)
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1183, in parse
>> tree.parse(source, parser)
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
>> self._root = parser.close()
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
>> self._raiseerror(v)
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
>> _raiseerror
>> raise err
>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>> 2) G6.4.3. and its gui can be properly launched (no problems like
>> mentioned in point 1). So here I tried to install add.ons. There I ran
>> g.extension from the grass terminal but face following problem:
>> GRASS 6.4.3 (gisdemo_ncspm):~ > g.extension extension=r.stream.order
>> Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
>> WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-U4bRKD/pkcs11:
>> No such file or directory
>> A r.stream.order/main.c
>> A r.stream.order/description.html
>> A r.stream.order/global.h
>> A r.stream.order/io.c
>> A r.stream.order/r_stream_order_orders.png
>> A r.stream.order/order.c
>> A r.stream.order/Makefile
>> U r.stream.order
>> Checked out revision 57991.
>> Compiling <r.stream.order>...
>> Makefile:12: /usr/lib/grass64/include/Make/Module.make: No such file or
>> directory
>> make: *** No rule to make target
>> `/usr/lib/grass64/include/Make/Module.make'. Stop.
>> ERROR: Compilation failed, sorry. Please check above error messages.
>> So does anyone have an idea what may cause the problems. I don't think
>> that the problems are related nor are they caused by my Xubuntu-Virtualbox
>> setup. Do I miss any modules/packages/software that I need to install prior
>> to grass? Or do I need to use different ppas for installing grass? Any help
>> is of course mostly welcome!
>> Best regards,
>> Johannes
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> *César Augusto Ramírez Franco*
> Tecnólogo en Telecomunicaciones - ITM
> Técnico certificado en Mantenimiento de Computadores - CESDE
> Móvil: 301 389 5607
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131014/599d94d8/attachment.html>
