[GRASS-user] libintl8.dll not found
Levente Juhász
jlevente89 at gmail.com
Wed Oct 16 02:33:10 PDT 2013
hey,
i've found out that GRASS 6 uses unix shell scripts and "MSYS is a
collection of GNU utilities such as bash, make, gawk and grep to allow
building of applications and programs which depend on traditionally UNIX
tools to be present." So basically that's why you need it.
If I am right you should install this (
http://sourceforge.net/projects/keithmarshall.u/files/mingw-get/mingw-get-setup.exe/download)
- or try to select msys package manually from OSGeo4W installer from here (
http://trac.osgeo.org/osgeo4w/)
Acoording to this ticket (http://trac.osgeo.org/osgeo4w/ticket/269) it will
do the trick.
Also upgrading to GRASS 7 could be a reasonable solution.
cheers,
Levente
2013/10/16 FNK <pablo.fnk.foncas at gmail.com>
> I've tried it installing in C:\GRASS642 and it hasn't worked.
> Thanks for your help.
> http://osgeo-org.1560.x6.nabble.com/libintl3-dll-not-found-tp5083833p5083842.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131016/0a37f7d7/attachment.html>
