[GRASS-user] Compilation error with g.extension v.krige
Daniel McInerney
daniel.o.mcinerney at gmail.com
Thu Oct 17 08:26:12 PDT 2013
Hi Alessandro,
On Thu, Oct 17, 2013 at 11:30 AM, Alessandro Sarretta <
alessandro.sarretta at gmail.com> wrote:
> Dear all,
> I'm trying to install v.krige via *g.extension v.krige* but I receive an
> error.
> My configurations are the followings:
> GRASS version:
> 6.4.3
> GRASS SVN
> Revision:
> GIS Library Revision: 50937
> (2012-02-25)
> GDAL/OGR:
> 1.10.0
> PROJ4: Rel. 4.8.0, 6 March
> 2012
> Python:
> 2.7.4
> wxPython:
> 2.8.12.1
> Platform: Linux-3.8.0-31-generic-x86_64-with-Ubuntu-13.04-raring
> Below the last lines of the command output:
> /usr/bin/install: target
> ‘/home/ale/Documents/grassdb/wgs84/PERMANENT/.tmp/sarretta-utos/32627.0/dist.x86_64/etc/wxpython/scripts/’
> is not a directory: No such file or directory**
> **make: *** [default] Error 1**
> **ERROR: Compilation failed, sorry. Please check above error messages.**
> I've read this
> http://lists.osgeo.org/pipermail/grass-user/2011-April/060329.html
> but I can't understand whether it is related with my problem or not.
> Do you have any ideas?
> Thank you very much for any suggestion!
I got the same error on GRASS 6.4 when I tried to install v.krige. As an
interim fix, you might consider running the trunk version of GRASS 7 as
v.krige is available there.
best regards,
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131017/6cbda0d4/attachment.html>
