[GRASS-user] r.stream.* addons issue
Bulent Arikan
bulent.arikan at gmail.com
Fri Oct 18 19:50:15 PDT 2013
Unfortunately, it still does not work. I downloaded the stable version of Grass from your website and I am having the same issue. Meanwhile, I am trying to remember an old trick I learned from a friend. I saved the .html file as a plain text file and dropped it into the Scripts folder in Contents>MacOS. I used to type a command starting with 'chmod' to make that plain text file a Unix executable file. It worked in the past for several addons.
BÜLENT
On Oct 19, 2013, at 1:39 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Actually, I think g.extension should work now, I forgot to update the readme. I haven't tried it from the GUI, or installing system-wide.
> On Oct 18, 2013, at 3:36 PM, Bulent Arikan wrote:
>> Thank you Ralf!
>> BÜLENT
>> On Oct 18, 2013, at 11:21 PM, Ralf Schäfer <senator at ecotoxicology.de> wrote:
>>> Dear Bulent
>>> g.extension does not work on Mac to my knowledge.
>>> There is a detailed description of an alternative how to build modules on Mac using a few lines in the Shell.
>>> If you install GRASS from kyngchaos, he provides a description in a readme file.
>>> http://www.kyngchaos.com/software/grass
>>> I do not know whether this description is compatible with the installation from Michael Barton.
>>> Best regards
>>> Ralf
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131019/b3c2866a/attachment.html>
