[GRASS-user] r.average issue with rasters at different resolutions
matteo poletti pollo1_91 at yahoo.it
Sat Oct 19 06:31:59 PDT 2013
Hi all,
I have an issue with the module r.average. I'm testing the module with a constant cover map so that I know the result I should get, but the output map has a different value. I have this problem only when I use a cover map and a base map with different resolutions.
Does anybody know how to fix this problem?
Thank you in advance,
Matteo
