[GRASS-user] sh: 1: v.net.components: not found
Gunnar Oehmichen oehm8895 at uni-landau.de
Thu Oct 24 07:02:49 PDT 2013
Dear GRASS user list,
While accessing GRASS via R i ran over the problem of missing a certain
GRASS function: v.net.components
System:
Distributor ID:	Ubuntu
Description:	Ubuntu 12.04.3 LTS
Release:	12.04
Codename:	precise
grass	6.4.1-1ubuntu2
Here is what i did in R (partly):
Created a stream network shape file via execGRASS( "v.net", ...)
and now I wanted to distinguish local stream networks:
execGRASS("v.net.components", flags="overwrite",
parameters=list(input="Stream_known_Network",
output="Stream_known_connectivity", method="weak"))
Fehler in parseGRASS(cmd, legacyExec = legacyExec) : The command
    v.net.components --interface-description
could not be run (127), and produced the error message:
Then I looked wether v.net.components is installed,
dpkg -L grass|gedit
/usr/lib/grass64/bin/v.neighbors
/usr/lib/grass64/bin/v.net
/usr/lib/grass64/bin/v.net.alloc
/usr/lib/grass64/bin/v.net.iso
/usr/lib/grass64/bin/v.net.path
/usr/lib/grass64/bin/v.net.salesman
/usr/lib/grass64/bin/v.net.steiner
/usr/lib/grass64/bin/v.net.visibility
/usr/lib/grass64/bin/v.normal
And it seems like, it is not.
Is my version generally missing the function?
Some help would be very much appreciated,
Thanks very Much,
Gunnar
Gunnar Oehmichen
Quantitative Landscape Ecology
Institute for Environmental Sciences
University Koblenz-Landau
Fortstrasse 7
76829 Landau
Germany
http://www.uni-koblenz-landau.de/landau/fb7/umweltwissenschaften/landscape-ecology/Staff/gunnaroehmichen
