[GRASS-user] g7 svn58117 r.random ERROR: There aren't [n] non-NULL cells in the current region
Eric Goddard
egoddard1010 at gmail.com
Mon Oct 28 12:33:43 PDT 2013
Thanks, Hamish. My machine is 64 bit. Making those changes results in the
same results posted above:
r.random -i --overwrite input=land_cover_classification at PERMANENT n=1000
vector_output=accuracy_assessment_random
Collecting Stats...
Raster: land_cover_classification at PERMANENT
Cover: (null)
Cell Count: -75090892
Null Cells: 2130552315
On Mon, Oct 28, 2013 at 2:01 PM, Hamish <hamish_b at yahoo.com> wrote:
> Eric wrote:
> >> rows: 64019
> >> cols: 65916
> >> cells: 4219876404
> 64019 * 65916 > signed 32bit integer so it overflows
> is your system+grass 32 or 64 bit?
> > A negative cell count? hmmm....
> that may just be a cosmetic issue in the printf'ing of the variables.
> the first thing I'd try is to go to line 124 in main.c and (1) remove
> the two casts to (int), then (2) change the two %d to %ld.
> (nCells and nNulls are defined as "long" in local_proto.h)
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131028/3c06a61a/attachment.html>
