[GRASS-user] Road directed network partitioning in k-subgraphs around source node?
G. Allegri giohappy at gmail.com
Thu Sep 5 03:50:35 PDT 2013
I try to explain my problem with an example:
I have 3 vehicles that must do some work on a road netowk.
The morning they will leave the station and will go to their working area.
I need to partition the road network under the following heursitic
constraints:
 -  the subgraphs must be connected
 -  they must have similar graph density
 -  the transfer time for the vehicles must be similar
I can start simplifying the problem: paritioning the road graph in k
subraphs, "radially" around the station, with k the number of vehicles.
giovanni
2013/9/5 G. Allegri <giohappy at gmail.com>
> I'm looking for a method to parition a road network in k connected
> subgraphs around a starting node (i.e. the source node must be on a
> subgraph cut edge of each subgraph).
> Is there anyone that have solved this kind of problem within GRASS?
> Regards,
> Giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130905/c12f9779/attachment.html>
