[GRASS-user] urgently!
Albert Saribekyan
albertsaribekyan at rambler.ru
Thu Sep 5 05:15:44 PDT 2013
Dear all,
I have a script, which calculates the ndvi in parallel on the server with 8
cores (OS is Debian GNU/Linux 6.0with Linux Kernel 2.6.32-5).
The experiments show that the images with the sizes up 500 MB successfully
run on all 2 to 8 cores, but in case of the 1GB image size when I run the
script on 5 cores I receive the following error:
"Gateway time-out, gateway didn't recieve a timely responce from the upstream
server or application"
Could you pls. let me know how to check and find out the reason (memory, HDD,
CPU)?
Regards
Albert Saribekyan.
grass-user �� lists.osgeo.org
�������� � ������� HTML ���� ���������…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130905/2651a0ea/attachment.html>
