[GRASS-user] DEM creation from aerial photography
Tim Bowden tim.bowden at mapforge.com.au
Mon Sep 9 19:44:04 PDT 2013
On Mon, 2013-09-09 at 08:43 -0400, Mark Seibel wrote:
> Hi.
> If all I've got is raw (ie, unrectified) aerial photography &
> sufficient
> > ground control points, what is the process for creating a DEM
> (assuming
> > it's possible with GRASS)?
> Are you looking to georeference an aerial image? Or create a Digital
> Elevation Model?  Each is a different, specific task.
> Mark
Both I guess, but the DEM is the end goal; that is the bit I haven't
been able to find any docs on, and noting what Marcus has posted it
seems there's quite a bit of work to be done getting that happening.
Thanks,
Tim
