[GRASS-user] importing a adf file - resolution question
Markus Metz
markus.metz.giswork at gmail.com
Wed Sep 25 01:11:57 PDT 2013
On Tue, Sep 24, 2013 at 6:57 PM, Kirk Wythers <kirk.wythers at gmail.com> wrote:
> I just used r.in.gdal to import a .adf. The files came from the global
> aridity and pet database hosted by CGIAR CSI
CGIAR CSI produces a lot of misaligned raster data.
> http://www.cgiar-csi.org/data/global-aridity-and-pet-database
> Originally I was getting the warning:
> WARNING: G_set_window(): Illegal latitude for North
> so I used the -l option. The file appears to have imported
> GRASS 6.4.3 (globe_30s):~ > r.in.gdal -l
> in=~/projects/global_aridity/AI_annual/ai_yr/w001001.adf out=ai
> WARNING: Map bounds have been constrained to geographic coordinates. You
> will almost certainly want to check map bounds and resolution with
> r.info and reset them with r.region before going any further.
As the message says, you need to fix the raster extents and resolution
with r.region
> GRASS 6.4.3 (globe_30s):~ > r.info ai
> | Layer: ai Date: Tue Sep 24 11:06:02 2013
> | Projection: Latitude-Longitude
> | N: 90N S: 60S Res: 0:00:30
North has been fixed during import, it was most probably larger than
90N with 90:00:00.067592N
> | E: 179:59:59.932408W W: 180W Res: 0:00:00.000002
That should most probably be E: 180E W: 180W
> I'm not sure what to do with this? Any suggestions would be most
> appreciated!
Thus try r.region map=ai e=180 w=-180
HTH,
Markus M
