[GRASS-user] t.rast.aggregate
Veronica Andreo
veroandreo at gmail.com
Tue Apr 1 07:21:40 PDT 2014
Great!!
Obviously I didn't think about that :P
THANKS!!!
Vero
2014-04-01 11:13 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi Veronica,
> 2014-04-01 16:07 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
>> Hi Soeren,
>> 2014-03-31 13:05 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
>>> Hi Veronica,
>>> you can use t.rast.series for this kind of task. Use a SQL expression
>>> to select only specific months of a year. Please try this code
>>> (untested, may contain errors):
>>> # January averages
>>> t.rast.series input=monthly_aggregates \
>>> output=jan_average method=average \
>>> where="start_time = datetime(start_time, 'start_of_year', '0 month')"
>> Thanks so much for your help! Worked perfectly just removing the
>> underscore in 'start of year'
> Ooops, sorry for the underscore's.
>> Have one question though: is there a way to check which maps were used
>> to estimate the average (or whatever operation t.rast.series perform)?
>> Is that information stored somewhere? or is there a way to check prior
>> to t.rast.series??
> You can use the same SQL expression in any other temporal command that
> support SQL where expressions. For example t.rast.list:
> t.rast.list input=precipitation_1950_2013_monthly_mm at soeren
> where="start_time = datetime(start_time, 'start of year', '0 month')"
> precipitation_monthly_mm_0 soeren 1950-01-01 00:00:00 1950-02-01 00:00:00
> precipitation_monthly_mm_12 soeren 1951-01-01 00:00:00 1951-02-01 00:00:00
> precipitation_monthly_mm_732 soeren 2011-01-01 00:00:00 2011-02-01 00:00:00
> precipitation_monthly_mm_744 soeren 2012-01-01 00:00:00 2012-02-01 00:00:00
> precipitation_monthly_mm_756 soeren 2013-01-01 00:00:00 2013-02-01 00:00:00
> Best regards
> Soeren
>> Thanks again!
>> Best,
>> Vero
