[GRASS-user] A little help compiling Grass 7.0 Beta1?
Rashad M
mohammedrashadkm at gmail.com
Fri Apr 11 00:10:43 PDT 2014
Hi David,
Did you updated LD_LIBRARY_PATH to find your local gdal. In your case
try export LD_LIBRARY_PATH=/usr/local/lib
On Thu, Apr 10, 2014 at 10:31 PM, David Strom <dstrom at ciesin.columbia.edu>wrote:
> I'm on a Centos 6.4 system. We need BigTiff support, so the Elgis versions
> don't work for us.
> So, I've built libgeotiff using libtiff4 (from elgis repo), then built
> gdal (/usr/local/bin/gdalinfo --version GDAL 1.9.2, released 2012/10/08);
> did the make installs into /usr/local for both, of course.
> Now having problems with Grass 7.0 Beta1, at compile time (make). Seems
> like it's not finding gdal lib:
> in display subdirectory :
> ... error while loading shared libraries: libgdal.so.1: cannot open shared
> object file: No such file or directory
> then again in general subdir, so I notice the pattern & look for that lib:
> find /usr/local -name libgdal.so.1 -print
> /usr/local/lib/libgdal.so.1
> /usr/local/share/gdal-trunk/.libs/libgdal.so.1
> /usr/local/hidelib/libgdal.so.1
> Any help on how to get past this?
> This the configure I'm using, from the suggested:
> ./configure \
> --with-libs=/usr/lib64 \
> --with-cxx \
> --without-ffmpeg \
> --with-gdal=/usr/local/bin/gdal-config \
> --without-odbc \
> --with-sqlite \
> --with-postgres \
> --without-mysql \
> --with-nls \
> --with-python \
> --with-cairo \
> --with-wxwidgets=/usr/bin/wx-config \
> --without-fftw \
> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
> --enable-largefile \
> --with-pthread
> /usr/local/bin/gdal-config is this:
> more /usr/local/bin/gdal-config
> #!/bin/sh
> CONFIG_LIBS="-L/usr/local/lib -lgdal"
> CONFIG_DEP_LIBS=" -lsqlite3 -lexpat -lgeotiff -ltiff -lpng -L/usr/lib64
> -lpq -lz -lpthread -lm -lrt -ldl -lcurl "
> CONFIG_PREFIX="/usr/local"
> CONFIG_CFLAGS="-I/usr/local/include"
> CONFIG_DATA="/usr/local/share/gdal"
> CONFIG_VERSION="1.9.2"
> CONFIG_OGR_ENABLED=yes
> CONFIG_FORMATS="gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts
> raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk
> airsar rs2 ilwis rmf leveller sgi srtmhgt idrisi gsg ingr ers jaxapalsar
> dimap gff cosar pds adrg coasp tsx terragen blx msgn til r northwoo
> d saga xyz hf2 kmlsuperoverlay ozi ctg e00grid zmap ngsgeoid wcs wms grib
> bsb gif jpeg png pcraster rik rasterlite postgisraster"
> usage()
> cat <<EOF
> Usage: gdal-config [OPTIONS]
> Options:
> [--prefix[=DIR]]
> [--libs]
> [--dep-libs]
> [--cflags]
> [--datadir]
> [--version]
> [--ogr-enabled]
> [--formats]
> EOF
> exit $1
> if test $# -eq 0; then
> usage 1 1>&2
> fi
> case $1 in
> --libs)
> echo $CONFIG_LIBS
> --dep-libs)
> echo $CONFIG_DEP_LIBS
> --cflags)
> echo $CONFIG_CFLAGS
> --datadir)
> echo $CONFIG_DATA
> --prefix)
> echo $CONFIG_PREFIX
> --version)
> echo $CONFIG_VERSION
> --ogr-enabled)
> echo $CONFIG_OGR_ENABLED
> --formats)
> echo $CONFIG_FORMATS
> usage 1 1>&2
> esac
> **** Thanks in advance for any/all assistance.
> David Strom
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140411/8591420f/attachment.html>
