[GRASS-user] Help needed for ascii point export
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue Apr 15 02:21:54 PDT 2014
On 15/04/14 08:13, jctorres wrote:
> Hello
> You can create a map of these points contining the elevation as
> attribute. Once you output this map you could sort points using the
> elevation values.
> you can do this for instance using v.to.rast to convert the points to
> raster, them combine this map with elevation using r.mapcalc (assigning
> elevation to the points), and them output the map using r.out.xyz.
> To sort the points you can use any sort program or a spreadsheet.
Maybe directly using v.what.rast might be easier...
And, Thomas, have you checked the category values of the points ? If the
points were created in stream order than the cat values should give the
correct order.
Moritz
> Best regards
> Juan Carlos Torres
> El 15/04/14 04:52, Thomas Adams escribió:
>> All:
>> I have a collection of points that represent the centerline of a
>> river. I need to output them in upstream to downstream order (or the
>> reverse). A simple v.out.ascii does not do this because of the channel
>> meanders. It's critical to get the x,y locations of these points in
>> the correct order.
>> Any help is appreciated!
>> Regards,
>> Tom
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Juan Carlos Torres                      |http://lsi.ugr.es/~jctorres
> Laboratorio de Realidad Virtual         | Tlf.: (+34) 645 885 167
> Dpto. Lenguajes y Sistemas Informaticos |       (+34) 958 249 307
> ETS. Ing. Informatica                   |     interno ugr  71 260
> Univ. de Granada                        | FAX: (+34) 958 243 179
