[GRASS-user] GRASS 6.4.3 fails to start
Markus Neteler
neteler at osgeo.org
Thu Apr 17 02:17:21 PDT 2014
On Sun, Apr 13, 2014 at 11:07 PM, jwd <jwd at surewest.net> wrote:
> Trying to start GRASS 6.4.3 from the GUI (KDE) shows the small
> welcome screen asking the user to choose a project location and map
> set, or define a new location and start GRASS. The splash screen then
> briefly appears. It then fails without a whimper. Trying to start
> GRASS in a console opens the same small window with options, the same
> flash of the splash screen, and then displays the following:
> GRASS 6.4.3 (RidgeCrest):~ > Traceback (most recent call last):
> File "/opt/grass/etc/wxpython/wxgui.py", line 139, in <module>
> sys.exit(main())
> File "/opt/grass/etc/wxpython/wxgui.py", line 132, in main
> app = GMApp(workspaceFile)
> File "/opt/grass/etc/wxpython/wxgui.py", line 45, in __init__
> wx.App.__init__(self, False)
> File "/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py",
> line 7981, in __init__ self._BootstrapApp()
> line 7555, in _BootstrapApp return _core_.PyApp__BootstrapApp(*args,
> **kwargs)
> File "/opt/grass/etc/wxpython/wxgui.py", line 78, in OnInit
> workspace = self.workspaceFile)
> File "/opt/grass/etc/wxpython/lmgr/frame.py", line 111, in __init__
> self.toolbars = { 'workspace' : LMWorkspaceToolbar(parent = self),
> File "/opt/grass/etc/wxpython/lmgr/toolbars.py", line 40, in __init__
> self.InitToolbar(self._toolbarData())
> File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 96, in InitToolbar
> self.CreateTool(*tool)
> File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 120, in CreateTool
> shortHelp, longHelp)
> File "/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py",
> line 3764, in AddLabelTool shortHelp, longHelp, clientData)
> line 3686, in DoAddTool return _controls_.ToolBarBase_DoAddTool(*args,
> **kwargs)
> ValueError: invalid null reference in method 'ToolBarBase_DoAddTool', expected argument 4 of type 'wxBitmap const &'
> GRASS does seem to have started, but there seems to be problem with
> initiating the tool bar?
Searching around, I found a similar message from long ago:
http://lists.osgeo.org/pipermail/grass-dev/2007-May/031321.html
Essentially an icon was not found. Perhaps you could check for this?
Markus
> I am running GRASS 6.4.3 on an Opensuse 13.1 with KDE 4.11.5 on an AMD
> Phenom II based platform.
> Suggestions or help appreciated.
> JWDougheryt
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
