[GRASS-user] Problem installing GRASS extension r.inund.fluv
Thomas Adams tea3rd at gmail.com
Fri Apr 18 11:31:59 PDT 2014
All,
I was able to successfully compile and install manually; simply using the
g.extension approach does not work. Use g.extension to download the source;
then go to the r.inund.fluv directory amd edit the Makeile as the
README.txt file indicates -- the "source" directory in the GISBASE PATH,
which for me is: /usr/local/grass-6.4.3
Use: sudo INST_NOW=y make  to compile & install
This seems to work. I'm just waiting on the command to complete now!!!!
Excited!
Tom
On Fri, Apr 18, 2014 at 1:23 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> I have tried a couple of times to use g.extension and below is what I get.
> I'm using GRASS 6.4.3 on the Ubuntu 13.04. I also have GRASS 7.0 installed,
> but r.inund.fluv is not available for it.
> Any thoughts?
> Thank you,
> Tom
> g.extension.py extension=r.inund.fluv svnurl=
> http://svn.osgeo.org/grass/grass-addons/grass6
> Fetching <r.inund.fluv> from GRASS-Addons SVN (be patient)...
> Compiling...
> /usr/local/grass-6.4.3/include/Make/Grass.make:423: warning:
> overriding commands for target
> `/home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-
> Wild-Dog-Performance/23864.0/r.inund.fluv/bin'
> /usr/local/grass-6.4.3/include/Make/Grass.make:414: warning:
> ignoring old commands for target
> /usr/local/grass-6.4.3/include/Make/Grass.make:390: warning:
> overriding commands for target `first'
> ignoring old commands for target `first'
> /usr/local/grass-6.4.3/include/Make/Grass.make:406: warning:
> overriding commands for target `inst_now'
> ignoring old commands for target `inst_now'
> /usr/local/grass-6.4.3/include/Make/Grass.make:417: warning:
> `/usr/local/grass-6.4.3/include/grass'
> /usr/local/grass-6.4.3/include/Make/Grass.make:420: warning:
> overriding commands for target `/usr/local/grass-6.4.3/lib'
> /usr/local/grass-6.4.3/include/Make/Grass.make:426: warning:
> Wild-Dog-Performance/23864.0/r.inund.fluv/etc/r.inund.fluv'
> /usr/local/grass-6.4.3/include/Make/Grass.make:429: warning:
> `/usr/local/grass-6.4.3/driver'
> /usr/local/grass-6.4.3/include/Make/Grass.make:432: warning:
> `/usr/local/grass-6.4.3/driver/db'
> /usr/local/grass-6.4.3/include/Make/Grass.make:435: warning:
> `/usr/local/grass-6.4.3/fonts'
> /usr/local/grass-6.4.3/include/Make/Rules.make:28: warning:
> overriding commands for target `OBJ.x86_64-unknown-linux-
> gnu'
> ignoring old commands for target `OBJ.x86_64-unknown-linux-
> gnu'
> /usr/local/grass-6.4.3/include/Make/Rules.make:89: warning:
> overriding commands for target `clean'
> ignoring old commands for target `clean'
> /usr/local/grass-6.4.3/include/Make/Html.make:40: warning:
> Wild-Dog-Performance/23864.0/r.inund.fluv/docs/html/r.inund.
> fluv.html'
> fluv.html'
> /usr/local/grass-6.4.3/include/Make/Html.make:45: warning:
> overriding commands for target `htmlcmd'
> ignoring old commands for target `htmlcmd'
> /usr/local/grass-6.4.3/include/Make/Html.make:49: warning:
> overriding commands for target `htmlscript'
> ignoring old commands for target `htmlscript'
> /usr/local/grass-6.4.3/include/Make/Html.make:53: warning:
> overriding commands for target `htmletc'
> ignoring old commands for target `htmletc'
> /usr/local/grass-6.4.3/include/Make/Html.make:57: warning:
> overriding commands for target `htmldir'
> ignoring old commands for target `htmldir'
> /usr/local/grass-6.4.3/include/Make/Html.make:61: warning:
> overriding commands for target `htmlmulti'
> ignoring old commands for target `htmlmulti'
> /usr/local/grass-6.4.3/include/Make/Man.make:38: warning:
> Wild-Dog-
> Performance/23864.0/r.inund.fluv/man/man1/r.inund.fluv.1'
> Wild-Dog-
> /usr/local/grass-6.4.3/include/Make/Man.make:43: warning:
> overriding commands for target `mancmd'
> ignoring old commands for target `mancmd'
> /usr/local/grass-6.4.3/include/Make/Man.make:47: warning:
> overriding commands for target `manscript'
> ignoring old commands for target `manscript'
> /usr/local/grass-6.4.3/include/Make/Man.make:51: warning:
> overriding commands for target `manetc'
> ignoring old commands for target `manetc'
> /usr/local/grass-6.4.3/include/Make/Man.make:55: warning:
> overriding commands for target `mandir'
> ignoring old commands for target `mandir'
> /usr/local/grass-6.4.3/include/Make/Man.make:59: warning:
> overriding commands for target `manmulti'
> ignoring old commands for target `manmulti'
> /usr/local/grass-6.4.3/include/Make/Module.make:25: warning:
> overriding commands for target `install'
> /usr/local/grass-6.4.3/include/Make/Script.make:48: warning:
> ignoring old commands for target `install'
> Makefile:31: warning: overriding commands for target `clean'
> Installing...
> overriding commands for target `/usr/local/bin'
> ignoring old commands for target `/usr/local/bin'
> Wild-Dog-Performance/23864.0/r.inund.fluv/include/grass'
> Wild-Dog-Performance/23864.0/r.inund.fluv/lib'
> Wild-Dog-Performance/23864.0/r.inund.fluv/etc'
> Wild-Dog-Performance/23864.0/r.inund.fluv/driver'
> Wild-Dog-Performance/23864.0/r.inund.fluv/driver/db'
> Wild-Dog-Performance/23864.0/r.inund.fluv/fonts'
> gnu'
> gnu'
> fluv.html'
> fluv.html'
> Wild-Dog-
> Wild-Dog-
> /usr/bin/install: cannot stat
> ‘/home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-
> Wild-Dog-
> Performance/23864.0/r.inund.fluv/bin/r.inund.fluv’: No
> such file or directory
> make: *** [install] Error 1
> WARNING: Installation failed, sorry. Please check above error messages.
> (Fri Apr 18 13:09:01 2014) Command finished (5
> sec)
> (Fri Apr 18 13:09:51
> 2014)
> Compiling...
> Wild-Dog-Performance/23942.0/r.inund.fluv/bin'
> Wild-Dog-Performance/23942.0/r.inund.fluv/etc/r.inund.fluv'
> gnu'
> gnu'
> Wild-Dog-Performance/23942.0/r.inund.fluv/docs/html/r.inund.
> fluv.html'
> fluv.html'
> Wild-Dog-
> Performance/23942.0/r.inund.fluv/man/man1/r.inund.fluv.1'
> Wild-Dog-
> Installing...
> Wild-Dog-Performance/23942.0/r.inund.fluv/include/grass'
> Wild-Dog-Performance/23942.0/r.inund.fluv/lib'
> Wild-Dog-Performance/23942.0/r.inund.fluv/etc'
> Wild-Dog-Performance/23942.0/r.inund.fluv/driver'
> Wild-Dog-Performance/23942.0/r.inund.fluv/driver/db'
> Wild-Dog-Performance/23942.0/r.inund.fluv/fonts'
> gnu'
> gnu'
> fluv.html'
> fluv.html'
> Wild-Dog-
> Wild-Dog-
> Wild-Dog-
> Performance/23942.0/r.inund.fluv/bin/r.inund.fluv’: No
> (Fri Apr 18 13:09:54 2014) Command finished (3 sec)
> Thomas E Adams, III
> 718 McBurney Drive
> Lebanon, OH 45036
> 1 (513) 739-9512 (cell)
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140418/7ec4b616/attachment-0001.html>
