[GRASS-user] Errors running r.inund.fluv
Thomas Adams tea3rd at gmail.com
Fri Apr 18 12:55:20 PDT 2014
I have output errors from running r.inund.fluv using GRASS 6.4.3. on Ubuntu
13.10 none of my output maps were written successfully; my DEM is coarse
(30m). But below is what I am getting in term window output -- much more
detail in the Command Window output, which I can provide.
Regards,
Tom
GRASS 6.4.3 (potomac_utm):~/grass/data > r.inund.fluv
GRASS_INFO_WARNING(25914,1): Table <limiti_alveo> not found in database
</home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> using driver
<sqlite>
GRASS_INFO_END(25914,1)
GRASS_INFO_ERROR(25916,1): Unable to describe table <limiti_alveo>
GRASS_INFO_END(25916,1)
(python:20172): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion
'index >= 0 && index <= layout->length' failed
GRASS_INFO_WARNING(28290,1): Table <limiti_alveo> not found in database
<sqlite>
GRASS_INFO_END(28290,1)
GRASS_INFO_ERROR(28292,1): Unable to describe table <limiti_alveo>
GRASS_INFO_END(28292,1)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140418/cd990a99/attachment.html>
