[GRASS-user] Shape file dbfs field name truncation leads to duplicate filed names on import
Markus Metz
markus.metz.giswork at gmail.com
Tue Apr 22 11:25:22 PDT 2014
On Mon, Apr 21, 2014 at 7:12 AM, jwd <jwd at surewest.net> wrote:
> I've been working at trying bring data from either shapefile or e00
> file into GRASS 6.4.3 However some of the layers simply do not
> import. The trouble seems to be that some of the column names in the
> shape dbf violate naming limits and result duplicate column names
> which cause a failure. E00 files (same data but different format) also
> result in a failure. As far as I can tell, the cause is the same. In
> some tables the process of importing the data results in duplicate
> field names due to truncation. Switching to the SQLite driver did not
> help here.
Hmm, switching to the SQLite driver should help. Did you use
db.connect driver=sqlite database="$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/"
or another command / other options. Note that you should use
$GISDBASE/$LOCATION_NAME/$MAPSET literally and not replace these
variables with their content.
What does db.connect -p say after switching to the SQLite dirver?
What are the error messages after switching to the SQLite dirver?
Markus M
> The data files are USGS coverages created originally in the '90s. If
> anyone has a recommended utility that can handle this problem, please
> let me know.
> JWDougherty
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
