[GRASS-user] Fill holes with an area bigger of a specific value in a raster coverage
Markus Neteler
neteler at osgeo.org
Tue Apr 29 13:07:50 PDT 2014
On Tue, Apr 29, 2014 at 6:48 PM, Jorge Arevalo
<jorgearevalo at libregis.org> wrote:
> I want to fill some areas of a raster coverage with a value of my choice.
> Those areas now contain NODATA values. So, they look like holes in my
> coverage.
If you want to set all NODATA area to the same value, then use r.null
with null=yourvalue:
http://grass.osgeo.org/grass70/manuals/r.null.html#examples
> I know I could use r.clump function , but I don't know how to specify the
> maximum area. Because if a hole is bigger than that area, I don't want to
> consider it as hole. Is that even possible with GRASS?
You could assign all NODATA areas a specific, yet unused value (see above).
Then extract this value with r.mapcalc (if condition) and extract from
the resulting map only the smaller areas with
http://grass.osgeo.org/grass70/manuals/r.reclass.area.html
Then merge them back with r.patch into the original maps in order to
create the final map.
Maybe there are other possibilities, too.
Markus
