[GRASS-user] GeoTIFF, EPSG and GRASS
Adrien ANDRÉ
adrien.andre at onf.fr
Thu Aug 21 06:32:04 PDT 2014
Hi!
with GDAL i use EPSG:2972 to reproject any new raster i'm lead to work with.
gdalinfo says:
Coordinate System is:
PROJCS["RGFG95 / UTM zone 22N",
GEOGCS["RGFG95",
DATUM["Reseau_Geodesique_Francais_Guyane_1995",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6624"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4624"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-51],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","2972"]]
I've created the GRASS location from this same code, and all imports are
successful.
After exporting, the gdalinfo output is different:
PROJCS["UTM Zone 22, Northern Hemisphere",
GEOGCS["grs80",
DATUM["unknown",
SPHEROID["Geodetic_Reference_System_1980", 6378137,
298.257222101]],
UNIT["degree",0.0174532925199433]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
The PROJCS has lost its AUTHORITY parameter.
Would someone know why this happens? Is there a way to fix this?
Thanks in advance,
regards,
Adrien
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140821/e8e32e6a/attachment.vcf>
