[GRASS-user] problem to install grass70 on ubuntu 12.04
    Markus Neteler
    neteler at osgeo.org
    Wed Aug 27 09:52:44 PDT 2014
Hi Sergio,
On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
<vignalisergio30 at gmail.com> wrote:
> Hi,
> I've just tried to install grass70 on ubuntu 12.04 by these command
> sudo add-apt-repository ppa:grass/grass-stable
> sudo apt-get update
> sudo apt-get install grass70 grass70-gui
> the error says that there are damaged or blocked packages
To better understand, I have created a virtual machine with Ubuntu
12.04 and tried myself. In fact:
pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 grass70 : Depends: grass70-core but it is not going to be installed
 grass70-gui : Depends: grass70-core but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
So I tried harder:
pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core grass70-gui
 grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
                Depends: libgeos-c1 (>= 3.4.2) but it is not going to
be installed
                Depends: libproj0 (>= 4.8.0-1) but it is not going to
be installed
                Recommends: gdal-bin but it is not going to be installed
                Recommends: proj-bin but it is not going to be installed
                Breaks: grass70 (< 7.0.0+0ubuntu3~)
Not sure what the next step is (I am more experienced with RPM based systems).
Likely it can be solved :-)
Markus
