I don't know why, but there appears to be a conflict between grass70 and
grass70-core packages.
I've been using that PPA on 14.04 but the package grass70 is not installed
in my system:
$ apt-cache policy grass70
grass70:
Instalados: (ninguno)
Candidato: 7.0.0~ppa~1~revno-30828~ubuntu14.04.1
Tabla de versión:
7.0.0~ppa~1~revno-30828~ubuntu14.04.1 0
500 http://ppa.launchpad.net/grass/grass-stable/ubuntu/ trusty/main
amd64 Packages
But grass70-core and grass70-gui are in fact installed
$ apt-cache policy grass70-core
grass70-core:
Instalados: 7.0.0~ppa~1~revno-30825~ubuntu14.04.1
Tabla de versión:
amd64 Packages
*** 7.0.0~ppa~1~revno-30825~ubuntu14.04.1 0
100 /var/lib/dpkg/status
$ apt-cache policy grass70-gui
grass70-gui:
Tabla de versión:
amd64 Packages
And grass is working OK, so I'd say the workaround should be issuing:
sudo apt-get install grass70-core grass70-gui
While the PPA maintenance team fixes that
2014-08-27 13:08 GMT-05:00 Markus Neteler <neteler at osgeo.org>:
> On Wed, Aug 27, 2014 at 6:52 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > Hi Sergio,
> > On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
> > <vignalisergio30 at gmail.com> wrote:
> >> Hi,
> >> I've just tried to install grass70 on ubuntu 12.04 by these command
> >> sudo add-apt-repository ppa:grass/grass-stable
> >> sudo apt-get update
> >> sudo apt-get install grass70 grass70-gui
> >> the error says that there are damaged or blocked packages
> > To better understand, I have created a virtual machine with Ubuntu
> > 12.04 and tried myself. In fact:
> > pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
> > Reading package lists... Done
> > Building dependency tree
> > Reading state information... Done
> > Some packages could not be installed. This may mean that you have
> > requested an impossible situation or if you are using the unstable
> > distribution that some required packages have not yet been created
> > or been moved out of Incoming.
> > The following information may help to resolve the situation:
> > The following packages have unmet dependencies:
> > grass70 : Depends: grass70-core but it is not going to be installed
> > grass70-gui : Depends: grass70-core but it is not going to be installed
> > E: Unable to correct problems, you have held broken packages.
> > So I tried harder:
> > pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core
> grass70-gui
> > grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
> > Depends: libgeos-c1 (>= 3.4.2) but it is not going to
> > be installed
> > Depends: libproj0 (>= 4.8.0-1) but it is not going to
> > be installed
> > Recommends: gdal-bin but it is not going to be installed
> > Recommends: proj-bin but it is not going to be installed
> > Breaks: grass70 (< 7.0.0+0ubuntu3~)
> > Not sure what the next step is (I am more experienced with RPM based
> systems).
> Just to complete the tests, also this fails at time:
> Depends: grass70-gui but it is not going to be installed
> > Likely it can be solved :-)
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/1e6bcbb7/attachment.html>
