[GRASS-user] grass-user Digest, Vol 100, Issue 24
Rengifo Ortega
rengifoo at yahoo.de
Wed Aug 27 13:53:35 PDT 2014
Hi Sergio,
Take a look at the link below. I had the same problem last week (among others ) while trying to install grass70 on ubuntu 14.04. The script kindly made available by hamish made the trick for me. Good luck
https://www.mail-archive.com/grass-user@lists.osgeo.org/msg28495.html
Best regards
Rengifo
"grass-user-request at lists.osgeo.org" <grass-user-request at lists.osgeo.org> schrieb am 21:00 Mittwoch, 27.August 2014:
Send grass-user mailing list submissions to
grass-user at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/grass-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
grass-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
1. Job Vacancy: Geospatial Software Engineer in Luxembourg
(Christian Braun)
2. problem to install grass70 on ubuntu 12.04 (Sergio Vignali)
3. Re: problem to install grass70 on ubuntu 12.04 (Markus Neteler)
4. Re: problem to install grass70 on ubuntu 12.04 (Markus Neteler)
Message: 1
Date: Wed, 27 Aug 2014 09:46:36 +0200
From: Christian Braun <christian.braun at tudor.lu>
To: GRASS user list <grass-user at lists.osgeo.org>,
freegis-list at intevation.de
Subject: [GRASS-user] Job Vacancy: Geospatial Software Engineer in
Luxembourg
Message-ID: <8EF1FEA6-ABCC-4716-982E-8AE26FDCF647 at tudor.lu>
Content-Type: text/plain; charset="us-ascii"
Dear all,
our Institute is looking for a candidate as a Geospatial Software Engineer.
Work will focus on the development of a geospatial web based framework, implementing OGC standards for sensor, data, catalogue and modelling services, enabling service based scenario simulation and decision support tools.
Further information and contact details can found here:
http://tudor.lu/en/job/geospatial-software-engineer-mf
Please apologize cross-posting.
kind regards,
Christian Braun
R+D Engineer
Environmental Modelling, Geocomputation
Tel: +352- 425991-6608
Mobil: +49-179-6845896
Mail: christian.braun at tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
6A, avenue des Hauts-Fourneaux,
L-4362 Esch-sur-Alzette, Luxembourg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/3408f315/attachment-0001.html>
Message: 2
Date: Wed, 27 Aug 2014 10:34:03 +0200
From: Sergio Vignali <vignalisergio30 at gmail.com>
Subject: [GRASS-user] problem to install grass70 on ubuntu 12.04
Message-ID:
<CALLUJBbZJ-=h0N0oj6wM9moHRZ6skNnd12pt4v6s-JNXXYKMsA at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
I've just tried to install grass70 on ubuntu 12.04 by these command
sudo add-apt-repository ppa:grass/grass-stable
sudo apt-get update
sudo apt-get install grass70 grass70-gui
the error says that there are damaged or blocked packages
All the best
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/e8ead687/attachment-0001.html>
Message: 3
Date: Wed, 27 Aug 2014 18:52:44 +0200
To: Sergio Vignali <vignalisergio30 at gmail.com>
Cc: GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] problem to install grass70 on ubuntu 12.04
Message-ID:
<CALFmHhuMMzu8ZWPWaMROtrAmo+5Pct-Yk12j_7uTT=K1M9WY6A at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Hi Sergio,
On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
<vignalisergio30 at gmail.com> wrote:
> Hi,
> sudo apt-get update
To better understand, I have created a virtual machine with Ubuntu
12.04 and tried myself. In fact:
pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grass70 : Depends: grass70-core but it is not going to be installed
grass70-gui : Depends: grass70-core but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
So I tried harder:
pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core grass70-gui
grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not going to
be installed
Depends: libproj0 (>= 4.8.0-1) but it is not going to
be installed
Recommends: gdal-bin but it is not going to be installed
Recommends: proj-bin but it is not going to be installed
Breaks: grass70 (< 7.0.0+0ubuntu3~)
Not sure what the next step is (I am more experienced with RPM based systems).
Likely it can be solved :-)
Markus
Message: 4
Date: Wed, 27 Aug 2014 20:08:29 +0200
Message-ID:
<CALFmHhu9afZMX_8fO+G4eOZBjzEAyWijpOcrSt+AjFEQPycJCg at mail.gmail.com>
On Wed, Aug 27, 2014 at 6:52 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Sergio,
>> Hi,
>> sudo apt-get update
> So I tried harder:
> be installed
> be installed
Just to complete the tests, also this fails at time:
Depends: grass70-gui but it is not going to be installed
Markus
End of grass-user Digest, Vol 100, Issue 24
-------------- n?chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/4aa126af/attachment-0001.html>
