[GRASS-user] problem to install grass70 on ubuntu 12.04
Sergio Vignali vignalisergio30 at gmail.com
Thu Aug 28 00:31:47 PDT 2014
Hi Rashad and Markus,
many thanks for your support!
This evening I'll try again, now I haven't an internet connection for my
laptop,
I'll update you later!
Sergio
2014-08-28 6:02 GMT+02:00 Rashad M <rashadkm at gmail.com>:
> Hi Sergio,
> I had a requested a new build right now on launchpad[1] which updates the
> grass70 startup script to releasebranch70.
> Could you wait for an hour or so before try installing grass again.
> (recipe build will happen in 6minutes)
> Sorry for the inconvenience and delay cause for you in installing
> packages.
> [1] https://code.launchpad.net/~grass/+recipe/grass70-release
> On Thu, Aug 28, 2014 at 5:33 AM, Rashad M <rashadkm at gmail.com> wrote:
>> Hi Markus,
>> I tried and this bug on ubuntu 12.04 and is reproducable. But for the
>> instant, to have grass70. (built 3 hrs ago)
>> he can try the below.
>> sudo add-apt-repository ppa:grass/grass-stable
>> You are about to add the following PPA to your system:
>>  GRASS Packages for the development release branch.
>> This is currently Version 7.0
>> NOTE:
>> These packages are NOT the OFFICIAL stable and tested packages by UBUNTU
>> & DEBIAN GIS team.
>> UBUNTU packages are found here:
>> https://launchpad.net/ubuntu/+source/grass
>> and UBUNTU GIS packages here:
>> * https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing
>> * https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
>> * https://launchpad.net/~ubuntugis/+archive/ppa
>>  More info: https://launchpad.net/~grass/+archive/ubuntu/grass-stable
>> Press [ENTER] to continue or ctrl-c to cancel adding it
>> gpg: keyring `/tmp/tmpfXSTNk/secring.gpg' created
>> gpg: keyring `/tmp/tmpfXSTNk/pubring.gpg' created
>> gpg: requesting key 26D57B27 from hkp server keyserver.ubuntu.com
>> gpg: /tmp/tmpfXSTNk/trustdb.gpg: trustdb created
>> gpg: key 26D57B27: public key "Launchpad PPA for GRASS GIS" imported
>> gpg: Total number processed: 1
>> gpg:               imported: 1  (RSA: 1)
>> OK
>> rashad at lsidev:~$ sudo apt-get update
>> rashad at lsidev:~$ sudo apt-get install grass70
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>>  grass70 : Depends: grass70-core but it is not going to be installed
>>            Depends: grass70-gui but it is not going to be installed
>> E: Unable to correct problems, you have held broken packages.
>> I will work on this issue and let you know
>> rashad at lsidev:~$ sudo apt-cache policy grass70
>> grass70:
>>   Installed: (none)
>>   Candidate: 7.0.0~ppa~1~revno-30832~ubuntu12.04.1
>>   Version table:
>>      7.0.0~ppa~1~revno-30832~ubuntu12.04.1 0
>>         500 http://ppa.launchpad.net/grass/grass-stable/ubuntu/
>> precise/main amd64 Packages
>> rashad at lsidev:~$ sudo apt-cache policy grass70-core
>> grass70-core:
>>   Installed: (none)
>>   Version table:
>> rashad at lsidev:~$ sudo apt-cache policy grass70-gui
>> grass70-gui:
>>   Installed: (none)
>>   Version table:
>> rashad at lsidev:~$ sudo apt-get install grass70-core grass70-gui
>> The following packages were automatically installed and are no longer
>> required:
>>    libopenal1:i386 bluez-alsa:i386 libsdl-ttf2.0-0:i386 libgconf-2-4:i386
>>   libstdc++5:i386 ia32-libs-multiarch:i386 libgail18:i386
>> libldap-2.4-2:i386
>>   libao-common libv4l-0:i386 libqt4-qt3support:i386
>> libroken18-heimdal:i386
>>   libunistring0:i386 libcupsimage2:i386 libgphoto2-port0:i386 libnss3:i386
>>   libcaca0:i386 gtk2-engines:i386 libgudev-1.0-0:i386
>> libcairo-gobject2:i386
>>   libavc1394-0:i386 ia32-libs libaio1:i386 libsane:i386
>> odbcinst1debian2:i386
>>   libqt4-test:i386 libqt4-designer:i386 libsdl-mixer1.2:i386 libcap2:i386
>>   libproxy1:i386 ibus-gtk:i386 libdbus-glib-1-2:i386 libtdb1:i386
>>   libasn1-8-heimdal:i386 libspeex1:i386 libxslt1.1:i386 libgomp1:i386
>>   libcapi20-3:i386 libibus-1.0-0:i386 libgssapi3-heimdal:i386
>>   libcanberra-gtk-module:i386 libcanberra0:i386 gtk2-engines-murrine:i386
>>   libwavpack1:i386 libqt4-opengl:i386 libsoup-gnome2.4-1:i386
>>   libv4lconvert0:i386 gstreamer0.10-plugins-good:i386 libiec61883-0:i386
>>   libsdl-image1.2:i386 libwind0-heimdal:i386 libsdl1.2debian:i386
>> libxaw7:i386
>>   libgdbm3:i386 libcurl3:i386 libesd0:i386 libmikmod2:i386
>>   libpulse-mainloop-glib0:i386 libaa1:i386 libieee1284-3:i386 libao4:i386
>>   libxmu6:i386 libcanberra-gtk0:i386 libvorbisfile3:i386 libxpm4:i386
>>   libqt4-svg:i386 libusb-0.1-4:i386 libgail-common:i386
>>   libhcrypto4-heimdal:i386 libraw1394-11:i386 libnspr4:i386 libshout3:i386
>>   libdv4:i386 libhx509-5-heimdal:i386 gstreamer0.10-x:i386
>> libgettextpo0:i386
>>   libgd2-xpm:i386 libheimbase1-heimdal:i386 libsdl-net1.2:i386
>>   libgnome-keyring0:i386 libxtst6:i386 gtk2-engines-pixbuf:i386
>>   libtag1c2a:i386 libssl0.9.8:i386 libmpg123-0:i386 libmad0:i386
>>   libsasl2-2:i386 gtk2-engines-oxygen:i386 lib32z1 xaw3dg:i386
>>   libheimntlm0-heimdal:i386 libpulsedsp:i386 libodbc1:i386 libexif12:i386
>>   libqt4-scripttools:i386 librtmp0:i386 libxp6:i386 libsasl2-modules:i386
>>   libltdl7:i386 libkrb5-26-heimdal:i386 glib-networking:i386
>> libsoup2.4-1:i386
>>   libgphoto2-2:i386 libtag1-vanilla:i386 libaudiofile1:i386
>> Use 'apt-get autoremove' to remove them.
>> Suggested packages:
>>   grass70-doc grass70-dev e00compr avce00 gnuplot xml2
>> The following NEW packages will be installed:
>> 0 upgraded, 2 newly installed, 0 to remove and 117 not upgraded.
>> Need to get 0 B/12.8 MB of archives.
>> After this operation, 37.5 MB of additional disk space will be used.
>> Selecting previously unselected package grass70-core.
>> (Reading database ... 479376 files and directories currently installed.)
>> Unpacking grass70-core (from
>> .../grass70-core_7.0.0~ppa~1~revno-30832~ubuntu12.04.1_amd64.deb) ...
>> Selecting previously unselected package grass70-gui.
>> Unpacking grass70-gui (from
>> .../grass70-gui_7.0.0~ppa~1~revno-30832~ubuntu12.04.1_amd64.deb) ...
>> Processing triggers for hicolor-icon-theme ...
>> Processing triggers for bamfdaemon ...
>> Rebuilding /usr/share/applications/bamf.index...
>> Processing triggers for desktop-file-utils ...
>> Processing triggers for gnome-menus ...
>> Processing triggers for man-db ...
>> Setting up grass70-core (7.0.0~ppa~1~revno-30832~ubuntu12.04.1) ...
>> Setting up grass70-gui (7.0.0~ppa~1~revno-30832~ubuntu12.04.1) ...
>> *grass70-core (7.0.0~ppa~1~revno-30832~ubuntu12.04.1*
>> The highlighted package can be seen on the ppa page[1]. Right now it says (3
>> hours ago)
>> On Wed, Aug 27, 2014 at 8:09 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>>> Hi Rashad,
>>> not sure if you read grass-user, so I take liberty to fwd to you this
>>> Ubuntu issue.
>>> Would be nice to get that fixed, would you be willing to?
>>> thanks
>>> Markus
>>> ---------- Forwarded message ----------
>>> From: Markus Neteler <neteler at osgeo.org>
>>> Date: Wed, Aug 27, 2014 at 8:08 PM
>>> Subject: Re: [GRASS-user] problem to install grass70 on ubuntu 12.04
>>> To: Sergio Vignali <vignalisergio30 at gmail.com>
>>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>>> On Wed, Aug 27, 2014 at 6:52 PM, Markus Neteler <neteler at osgeo.org>
>>> wrote:
>>> > Hi Sergio,
>>> > On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
>>> > <vignalisergio30 at gmail.com> wrote:
>>> >> Hi,
>>> >> I've just tried to install grass70 on ubuntu 12.04 by these command
>>> >> sudo apt-get update
>>> >> sudo apt-get install grass70 grass70-gui
>>> >> the error says that there are damaged or blocked packages
>>> > To better understand, I have created a virtual machine with Ubuntu
>>> > 12.04 and tried myself. In fact:
>>> > pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
>>> >  grass70-gui : Depends: grass70-core but it is not going to be
>>> installed
>>> > So I tried harder:
>>> > pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core
>>> grass70-gui
>>> >  grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
>>> >                 Depends: libgeos-c1 (>= 3.4.2) but it is not going to
>>> > be installed
>>> >                 Depends: libproj0 (>= 4.8.0-1) but it is not going to
>>> > be installed
>>> >                 Recommends: gdal-bin but it is not going to be
>>> installed
>>> >                 Recommends: proj-bin but it is not going to be
>>> installed
>>> >                 Breaks: grass70 (< 7.0.0+0ubuntu3~)
>>> > Not sure what the next step is (I am more experienced with RPM based
>>> systems).
>>> Just to complete the tests, also this fails at time:
>>> > Likely it can be solved :-)
>>> Markus
>> Take care
> Take care
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140828/e04b5d55/attachment-0001.html>
