[GRASS-user] Topological Trouble
James Keener
jim at jimkeener.com
Thu Aug 28 04:40:17 PDT 2014
I'm trying to create a map with isolines for the road-distance places
are from bus routes. I was trying to roughly follow
http://jcastellssala.wordpress.com/2012/05/07/basic-network-analysis-with-grass/
but I don't quite get similar results (I feel like the network isn't
completely connected, but this is the first time I'm doing this so it's
more likely I'm just doing it wrong.
I am using the following shapefiles in SRID 2272 (NAD83 / Pennsylvania
South (ftUS)):
http://jimkeener.com/grass-topo-question/roads.tar.bz2 which is the
TIGER road graph for Allegheny County, PA, USA (state fips = 42, county
fips = 003), but reprojected to 2272 and a "length" attribute added.
http://jimkeener.com/grass-topo-question/stops.tar.bz2 which is derived
from the Port Authority of Allegheny County GTFS file found at
http://www.portauthority.org/paac/CompanyInfoProjects/DeveloperResources.aspx
and reprojected to 2272.
So, the first thing I did is import these files:
> v.in.ogr dsn=roads.shp layer=roads output=roads
> v.in.ogr dsn=stops.shp layer=stops output=stops
(http://jimkeener.com/grass-topo-question/ac.png)
Then I connect the stops to the network
> v.net input=roads points=stops output=network operation=connect thresh=500
Connect the require database layer
> v.db.connect map=network table=schools layer=2
Then allocate the network
> v.net.alloc --overwrite --verbose input=network output=network_alloc ccats=1-6965
(http://jimkeener.com/grass-topo-question/ac-alloc-zoom-thumb.png when
displayed with d.vect -c) (the little Xs are bus stops
And create isolines at 1-, 2-, and 3- thousand feet
> v.net.iso --overwrite input=network output=network_isolines ccats=1-6965 costs=1000,2000,3000 afcolumn=LENGTH abcolumn=LENGTH
(http://jimkeener.com/grass-topo-question/ac-isolines-zoom.png also with
d.vect -c)
All but a few of the roadways near the open space to the right (a park
and very hilly (even by Pittsburgh standards:-p) area) are within 3000
feet of a bus stop. Therefor I was expecting almost all of the roads to
be highlighted in different colors representing their distance from a stop.
Thank you for any help!
Jim
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140828/28fc6f0c/attachment.pgp>
