[GRASS-user] GRASS r.flow command error
Moritz Lennert mlennert at club.worldonline.be
Fri Aug 29 02:20:51 PDT 2014
On 28/08/14 00:53, john polo wrote:
> Hi,
> I am using the r.flow command from the GRASS toolset inside of QGIS with
> no success. My apologies if this should be on QGIS-users instead. The
> raster file I am using is an elevation map from USDA's data gateway. I'm
> on a Win 7 64bit machine with QGIS 2.4 just recently installed.
This definitely is a QGIS issue, so you should address them.
Moritz
