[GRASS-user] v.krige
John Nicholls johnnicholls at fastmail.fm
Sun Aug 31 11:29:51 PDT 2014
Hi
I wonder if anyone can give me some further hints with v.krige. I have a
4 hectare data set with measurements spaced 10cm apart along parallel
lines 0.5m apart. Region resolution is set to 1.
The output from GRASS 7 below goes no further than "Path to PROJ.4
shared files: (autodetected)".
Likely I am missing something (?).
I have libgeos-dev, libproj-dev, build-essential, and rpy2 installed.
Thanks for any hints at where I am going wrong.
John.
(Sat Aug 30 21:53:18 2014)
v.krige input=tv1236_out_shft at user1 column=z1
output=tv1236_out_shft_kriging_res1 package=gstat --overwrite
output_var=tv1236_out_shft_kriging.var_res1
Loading dependencies, please wait...
Processing 76616 cells. Computing time raises exponentially
with
resolution.
Importing data...
rgeos version: 0.3-6, (SVN revision 450)
 GEOS runtime version: 3.4.2-CAPI-1.8.2 r3921
 Polygon checking: TRUE
Attaching package: ‘XML’
The following object is masked from ‘package:tools’:
    toHTML
GRASS GIS interface loaded with GRASS version: GRASS 7.0.0svn (2014)
and location: 14009
Checking rgeos availability: TRUE
Loading required package: automap
Loading required package: rgdal
rgdal: version: 0.8-16, (SVN revision 498)
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.10.1, released 2013/08/26
Path to GDAL shared files: /usr/share/gdal/1.10
Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
Path to PROJ.4 shared files: (autodetected)
http://www.fastmail.fm - A no graphics, no pop-ups email service
