[GRASS-user] Appending a map to another
    tommaso
    tommasodb at googlemail.com
    Mon Dec  8 05:37:51 PST 2014
Hello, I'm trying to simply append a map to other map, without any sort of
geometric operations as merge or intersects, just the original geometries
with theirs original attributes.
I'm using grass 6.4 on ubuntu 14.04, sqlite driver
This is what I already tried:
# input maps are poly2 and poly3
# First, I change the categories of one of the maps (poly3) to avoid
categories conflicts:
# see http://grass.osgeo.org/grass64/manuals/v.patch.html
v.category in=poly3 option=sum cat=10000 out=poly3_category --overwrite
g.remove vect=poly3
g.rename vect=poly3_category,poly3
# I update the cat column of the table as well (why this is not done
automatically by v.category??)
v.db.update poly3 col=cat qcol="cat+10000"
# now the to maps are patched together
db.droptable -f table=polygons
v.patch -e input=poly2,poly3 output=polygons --overwrite
# export to result as geojson:
v.out.ogr in=polygons olayer=polygons format=GeoJSON
dsn=/tmp/polygons.json type=area
The geometries of the result map polygons.json look good, but the
attributes are messy: I can not distinguish which records come from poly2
and which ones from poly3. Many records have only empty attributes. What
I'm doing wrong?
