[GRASS-user] problems with r.mapcalc
Diana Brito dianisbrito2 at gmail.com
Mon Dec 8 13:23:11 PST 2014
Hi list,
first, i'm new with grass
Im trying to do some math calculations with r.mapcalc, but my result
allways is nan.
When I display the image I can see different values, not only nan.
Thanks
GRASS 7.1.svn (sequia):/opt/grass_trunk/bin.x86_64-unknown-linux-gnu >
r.info NDVI_1_h11v11
 | Map:      NDVI_1_h11v11                  Date: Mon Dec  1 05:12:28 2014
 | Mapset:   sequia                         Login of Creator: polzader
 | DataBase: /home/polzader/Documentos/grassdata_diana_bpr
 | Title:     ( NDVI_1_h11v11 )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    DCELL
 |   Rows:         4409
 |   Columns:      7499
 |   Total Cells:  33063091
 |        Projection: Latitud - Longitud.
 |            N: 19:54:02.16S    S: 30:01:58.200271S   Res: 0:00:08.273087
 |            E: 63:35:44.521118W    W: 80:49:44.4W   Res: 0:00:08.273087
 |   Range of data:    min = -2000  max = 9090
 |   Data Description:
 |    generated by r.series
 |   Comments:
 |    r.series input="MOD13Q1.A2004001.h11v11.005.2007235231758.250m_16_da\
 |   ys_NDVI,MOD13Q1.A2005001.h11v11.005.2007352072715.250m_16_days_NDVI,\
 |    MOD13Q1.A2006001.h11v11.005.2008064055525.250m_16_days_NDVI,MOD13Q1.\
 |    A2007001.h11v11.005.2007021105928.250m_16_days_NDVI,MOD13Q1.A2008001\
 |    .h11v11.005.2008019102106.250m_16_days_NDVI,MOD13Q1.A2009001.h11v11.\
 |    005.2009019230008.250m_16_days_NDVI,MOD13Q1.A2010001.h11v11.005.2010\
 |    027061330.250m_16_days_NDVI,MOD13Q1.A2011001.h11v11.005.201102405534\
 |    0.250m_16_days_NDVI,MOD13Q1.A2012001.h11v11.005.2012019103715.250m_1\
 |    6_days_NDVI,MOD13Q1.A2013001.h11v11.005.2013018034332.250m_16_days_N\
 |    DVI,MOD13Q1.A2014001.h11v11.005.2014018092301.250m_16_days_NDVI,MOD1\
 |    3Q1.A2004017.h11v11.005.2008224113415.250m_16_days_NDVI,MOD13Q1.A200\
 |    5017.h11v11.005.2007353093413.250m_16_days_NDVI,MOD13Q1.A2006017.h11\
 |    v11.005.2008278011906.250m_16_days_NDVI,MOD13Q1.A2007017.h11v11.005.\
 |    2007096165508.250m_16_days_NDVI,MOD13Q1.A2008017.h11v11.005.20080370\
 |    54317.250m_16_days_NDVI,MOD13Q1.A2009017.h11v11.005.2009035200807.25\
 |    0m_16_days_NDVI,MOD13Q1.A2010017.h11v11.005.2010036002816.250m_16_da\
 |    ys_NDVI,MOD13Q1.A2011017.h11v11.005.2011039201212.250m_16_days_NDVI,\
 |    MOD13Q1.A2012017.h11v11.005.2012046172118.250m_16_days_NDVI,MOD13Q1.\
 |    A2013017.h11v11.005.2013039191638.250m_16_days_NDVI,MOD13Q1.A2014017\
 |    .h11v11.005.2014038143732.250m_16_days_NDVI" output="NDVI_1_h11v11" \
 |    method="average"
r.info NDWI_1_h11v11
 | Map:      NDWI_1_h11v11                  Date: Mon Dec  1 05:49:38 2014
 | Title:     ( NDWI_1_h11v11 )
 | Timestamp: none
 |   Data Type:    DCELL
 |   Rows:         4409
 |   Columns:      7499
 |   Range of data:    min = -9254.65838509317  max = 9247.07852234276
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    (NIR_reflectance_1_h11v11 - MIR_reflectance_1_h11v11) /
 |    (NIR_reflectance_1_h11v11 + MIR_reflectance_1_h11v11) * 10000
r.mapcalc --o expression="bla=NDVI_1_h11v11 - NDWI_1_h11v11"
r.info bla
 | Map:      bla                            Date: Mon Dec  8 18:04:41 2014
 | Title:     ( bla )
 | Timestamp: none
 |   Data Type:    DCELL
 |   Rows:         2861
 |   Columns:      9350
 |   Total Cells:  26750350
 |            N: 49:42:30.96S    S: 60:04:18.329421S   Res: 0:00:13.039975
 |            E: 46:24:51.430659W    W: 80:16:55.2W   Res: 0:00:13.039975
 |   Range of data:    min = -nan  max = -nan
 |   Data Description:
 |   Comments:
Diana Marcela Brito Hoyos
Biologa
d.brito at javeriana.edu.co
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141208/e68f01a5/attachment.html>
