[GRASS-user] problems with r.mapcalc
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Dec 8 13:47:58 PST 2014
Not sure that will give you a solution, but an r.mapcalc expression in
grass 7.1 should look like:
r.mapcalc --overwrite expression="bla = NDVI_1_h11v11 - NDWI_1_h11v11"
In other words 1) the --o flag in grass 6.4 was changed to --overwrite in
grass 7 and higher, and 2) there should be a space before the first *=*
sign.
Check out: http://grass.osgeo.org/grass71/manuals/r.mapcalc.html
Paulo
On Mon, Dec 8, 2014 at 10:23 PM, Diana Brito <dianisbrito2 at gmail.com> wrote:
> Hi list,
> first, i'm new with grass
> Im trying to do some math calculations with r.mapcalc, but my result
> allways is nan.
> When I display the image I can see different values, not only nan.
> Thanks
> GRASS 7.1.svn (sequia):/opt/grass_trunk/bin.x86_64-unknown-linux-gnu >
> r.info NDVI_1_h11v11
> | Map: NDVI_1_h11v11 Date: Mon Dec 1 05:12:28 2014
> | Mapset: sequia Login of Creator: polzader
> | Location: sequia
> | DataBase: /home/polzader/Documentos/grassdata_diana_bpr
> | Title: ( NDVI_1_h11v11 )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 0
> | Data Type: DCELL
> | Rows: 4409
> | Columns: 7499
> | Total Cells: 33063091
> | Projection: Latitud - Longitud.
> | N: 19:54:02.16S S: 30:01:58.200271S Res: 0:00:08.273087
> | E: 63:35:44.521118W W: 80:49:44.4W Res: 0:00:08.273087
> | Range of data: min = -2000 max = 9090
> | Data Description:
> | generated by r.series
> | Comments:
> | r.series
> input="MOD13Q1.A2004001.h11v11.005.2007235231758.250m_16_da\ |
> | ys_NDVI,MOD13Q1.A2005001.h11v11.005.2007352072715.250m_16_days_NDVI,\
> MOD13Q1.A2006001.h11v11.005.2008064055525.250m_16_days_NDVI,MOD13Q1.\ |
> A2007001.h11v11.005.2007021105928.250m_16_days_NDVI,MOD13Q1.A2008001\ |
> .h11v11.005.2008019102106.250m_16_days_NDVI,MOD13Q1.A2009001.h11v11.\ |
> 005.2009019230008.250m_16_days_NDVI,MOD13Q1.A2010001.h11v11.005.2010\ |
> 027061330.250m_16_days_NDVI,MOD13Q1.A2011001.h11v11.005.201102405534\ |
> 0.250m_16_days_NDVI,MOD13Q1.A2012001.h11v11.005.2012019103715.250m_1\ |
> 6_days_NDVI,MOD13Q1.A2013001.h11v11.005.2013018034332.250m_16_days_N\ |
> DVI,MOD13Q1.A2014001.h11v11.005.2014018092301.250m_16_days_NDVI,MOD1\ |
> 3Q1.A2004017.h11v11.005.2008224113415.250m_16_days_NDVI,MOD13Q1.A200\ |
> 5017.h11v11.005.2007353093413.250m_16_days_NDVI,MOD13Q1.A2006017.h11\ |
> v11.005.2008278011906.250m_16_days_NDVI,MOD13Q1.A2007017.h11v11.005.\ |
> 2007096165508.250m_16_days_NDVI,MOD13Q1.A2008017.h11v11.005.20080370\ |
> 54317.250m_16_days_NDVI,MOD13Q1.A2009017.h11v11.005.2009035200807.25\ |
> 0m_16_days_NDVI,MOD13Q1.A2010017.h11v11.005.2010036002816.250m_16_da\ |
> ys_NDVI,MOD13Q1.A2011017.h11v11.005.2011039201212.250m_16_days_NDVI,\ |
> MOD13Q1.A2012017.h11v11.005.2012046172118.250m_16_days_NDVI,MOD13Q1.\ |
> A2013017.h11v11.005.2013039191638.250m_16_days_NDVI,MOD13Q1.A2014017\ |
> | .h11v11.005.2014038143732.250m_16_days_NDVI" output="NDVI_1_h11v11"
> | method="average"
> r.info NDWI_1_h11v11
> | Map: NDWI_1_h11v11 Date: Mon Dec 1 05:49:38 2014
> | Location: sequia
> | Title: ( NDWI_1_h11v11 )
> | Timestamp: none
> | Data Type: DCELL
> | Rows: 4409
> | Columns: 7499
> | Range of data: min = -9254.65838509317 max = 9247.07852234276
> | Data Description:
> | generated by r.mapcalc
> | Comments:
> | (NIR_reflectance_1_h11v11 - MIR_reflectance_1_h11v11) /
> | (NIR_reflectance_1_h11v11 + MIR_reflectance_1_h11v11) * 10000
> r.mapcalc --o expression="bla=NDVI_1_h11v11 - NDWI_1_h11v11"
> r.info bla
> | Map: bla Date: Mon Dec 8 18:04:41 2014
> | Location: sequia
> | Title: ( bla )
> | Timestamp: none
> | Data Type: DCELL
> | Rows: 2861
> | Columns: 9350
> | Total Cells: 26750350
> | N: 49:42:30.96S S: 60:04:18.329421S Res: 0:00:13.039975
> | E: 46:24:51.430659W W: 80:16:55.2W Res: 0:00:13.039975
> | Range of data: min = -nan max = -nan
> | Data Description:
> | Comments:
> Diana Marcela Brito Hoyos
> Biologa
> d.brito at javeriana.edu.co
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141208/68ec9f3e/attachment-0001.html>
