[GRASS-user] randomize the position of a raster map
Moritz Lennert mlennert at club.worldonline.be
Tue Dec 9 06:55:59 PST 2014
On 08/12/14 18:26, Milton Ribeiro wrote:
> Hi all,
> I have a landcover maps, and I need to randomize the position of them,
> keeping all the pixels on the new raster map.
IIUC, you actually want to randomize the categories of pixels where
categories are land covers and there is a constraint that you want to
keep the same number of pixels per category. Is that correct ?
> Is there a command that can do this within GRASS?
You could use r.random following a procedure something like this:
create a raster (mymask) where all cells are non-null
for each category of land cover,
	get cat and percentage of cover of that cat (e.g. via r.stats)
	run r.random, using cover=mymask and n=percentage of cover
	modify mymask so that the cells attributed in the previous run of
r.random get set to null to make them unavailable in the next run
There is just one issue: the cover option in r.random provokes a check
if the randomly selected cell is in the cover area or not. If not, it is
not used, but no replacement is found, so if you use cover= the
percentage value in n= is not respected... Ideally this should be
corrected to while cell number X is not within the cover, find a new
cell. See [1] for an old discussion about this.
Attached is a bash script that tries to work around this issue and works
more or less for me (at least with the "landuse dataset in the
simplified NC dataset). Certainly not perfect, but maybe you can build
on that.
Another option might be something like this:
Knowing that:
r.stats -ncp landuse --quiet
1 73077 29.31%
2 2137 0.86%
3 25518 10.24%
4 16829 6.75%
5 126265 50.64%
6 5303 2.13%
7 194 0.08%
use the random generator in r.mapcalc
r.mapcalc "eval(random = rand(0.0,1.0)); landuse_randomized_mapcalc =
if(random<=0.2931,1, if(random>0.2931 && random
<=0.3017,2,if(random>0.3017 && random <=0.4041, 3, if(random>0.4041 &&
random<=0.4716, 4, if(random > 0.4716 && random <=0.9780, 5,
if(random>0.9780 && random <=0.9993, 5, 6))))))"  --o
The result is not perfect in terms of cell counts, but close:
r.stats -ncp landuse_randomized_mapcalc --quiet
1 73402 29.46%
2 2061 0.83%
3 25215 10.12%
4 16982 6.82%
5 131484 52.78%
6 180 0.07%
Moritz
[1] https://trac.osgeo.org/grass/ticket/1082
Type: application/x-shellscript
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141209/c94f3f6a/attachment.bin>
