[GRASS-user] i.segment.hierarchical on windows?
Vaclav Petras
wenzeslaus at gmail.com
Tue Dec 9 11:32:15 PST 2014
On Tue, Dec 9, 2014 at 1:52 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> anyone used i.segment.hierarchical in winGRASS7?
> seems not to work here; GUI can't be opened
> I'm just looking at the MS Windows build logs. There is the strange issue
which was discussed some time ago on grass-dev if I remember correctly.
is not going to be frozen to produce a Windows executable.''')
RuntimeError:
Attempt to start a new process before the current process
has finished its bootstrapping phase.
And there is also:
File
"c:\osgeo4w\usr\src\grass70_release\dist.i686-pc-mingw32\etc\python\grass\pygrass\raster\buffer.py",
line 8, in <module>
FCELL = (np.float, np.float16, np.float32)
AttributeError: 'module' object has no attribute 'float16'
What is your error message if any? What about command line?
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0svn/logs/
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0svn/logs/i.segment.hierarchical.log
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141209/424d2945/attachment.html>
