[GRASS-user] i.segment.hierarchical on windows?
Pietro
peter.zamb at gmail.com
Wed Dec 10 00:54:44 PST 2014
Hi Helmut,
On Wed, Dec 10, 2014 at 9:48 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>> FCELL = (np.float, np.float16, np.float32)
>>> AttributeError: 'module' object has no attribute 'float16'
>>Ok, this should be fix in r63462.
> AFAIK float16 data type was introduced in NumPy 1.6, while OSGeo4W based
> winGRASS uses 1.5.
ok, now should be loaded only if available.
>>If I don't put an empty html file the make command give me an
>>error... Of course I should add some more details, but I didn't have
>>time for this.
> I've added a manual skeleton by r63463
> (http://lists.osgeo.org/pipermail/grass-commit/2014-December/034373.html)
Thanks! I will try to fill it with a small example.
Best regards
Pietro
