[GRASS-user] can not locate "g.mlist"
Nikos Alexandris nik at nikosalexandris.net
Fri Dec 12 01:55:11 PST 2014
Rajat Nayak wrote:
> ...compiling from the source code in Ubuntu can create problems if
> not
> configured properly. I will try to work on it in free time.
Sorry, which version do you compile?  I don't run Ubuntu myself
(anymore, since quite some time).  But I used to do this very (very)
often. Which instructions do you follow?
You probably know this one:
<http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu>. Go through
the "checks" also:
<http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Post_compilation.2Finstallation_control>,
<http://grasswiki.osgeo.org/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin#Troubleshooting>.
Nikos
