[GRASS-user] Problem with r.basin in grass7
Helmut Kudrnovsky
hellik at web.de
Mon Dec 15 00:29:02 PST 2014
> r.basin map=elev_ned_30m at PERMANENT <=
>My result of g.region -p is:
>projection: 99 (Lambert Conformal Conic)
>zone: 0
>datum: nad83
>ellipsoid: a=6378137 es=0.006694380022900787
>north: 228513
>south: 214975.5
>west: 629992.5
>east: 645012
>nsres: 28.5 <=
>ewres: 28.5 <=
>rows: 475
>cols: 527
>cells: 250325
are you setting your region to match elev_ned_30m at PERMANENT?
here:
r.info map=elev_ned_30m at PERMANENT
| Map: elev_ned_30m at PERMANENT Date: Tue Nov 7 00:35:18 2006
| Mapset: PERMANENT Login of Creator: helena
| DataBase: C:\grassdata
| Title: South-West Wake county: National Elevation Data 30m (
elev_ned30 |
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 450
| Columns: 500
| Total Cells: 225000
| Projection: Lambert Conformal Conic
| N: 228500 S: 215000 Res: 30 <=
| E: 645000 W: 630000 Res: 30 <=
| Range of data: min = 55.1736 max = 156.3865
| Data Description:
| generated by r.proj
| Comments:
| r.proj input="ned1arcsec" location="northcarolina_latlong" mapset="h\
| elena" output="elev_ned30m" method="cubic" resolution=30
nsres: 28.5 vs 30?
please copy/paste this command:
g.region -a raster=elev_ned_30m at PERMANENT align=elev_ned_30m at PERMANENT
this means: matching region extent to raster DEM _and_ align cells to raster
DEM
here I get:
g.region -p -a raster=elev_ned_30m at PERMANENT align=elev_ned_30m at PERMANENT
zone: 0
datum: nad83
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 30 <=
ewres: 30 <=
rows: 450
cols: 500
cells: 225000
tested your command here on my side:
r.basin map=elev_ned_30m at PERMANENT prefix=b
coordinates=636654.791181,218824.126649 dir=C:\tmp\test threshold=40
(Mon Dec 15 09:13:17 2014) Befehl ausgeführt (4 Min 53 Sek)
r.basin finishes without any error.
>ERROR: Error while executing: 'DROP TABLE summary'
>Traceback (most recent call last):
no idea about this one ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5177858.html
Sent from the Grass - Users mailing list archive at Nabble.com.
