[GRASS-user] Interpolation method for parallel samples
Markus Metz markus.metz.giswork at gmail.com
Wed Dec 17 13:11:11 PST 2014
Martin Album Ytre-Eide wrote:
> Hello!
> I have airborne gamma measurements obtain in lines. The spatial distance
> between the 'points' along the line is 50m (e-w direction) and the spatial
> distance between the lines is 1000m (n-s direction)
> I am currently experimenting with the v.surf.bspline function - setting
> ew_step=100 and ns_step=1000. I am having trouble setting the ew_step any
> lower.....?
What exactly is the trouble with setting ew_step any lower? In theory,
it should be possible to set ew_step to any value.
Markus M
> I am also using the smoothing parameter lambda_i.
> If anyone have some interpolation tips with this type of data - I would be
> happy to hear about it.
> Martin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
