[GRASS-user] FYI - Output from compiling most recent release 7.0
Glynn Clements
glynn at gclements.plus.com
Sat Feb 8 11:10:43 PST 2014
Markus Neteler wrote:
> To me it looks like that you have an outdated libtiff on your sytem.
AFAICT, the problem is from trying to use an uninstalled libtiff:
I note that the related compilation commands have
-I/usr/src/tiff-4.0.3/build/include
while the linking commands have
-L/usr/src/tiff-4.0.3/build/lib
That will be enough for building shared libraries which link against
libtiff. But when it comes to building executables which use those
libraries, you'll also need (I think)
-Wl,-rpath-link,/usr/src/tiff-4.0.3/build/lib
This can be added by modifying the value of TIFFLIB or TIFFLIBPATH in
include/Make/Platform.make (or supplying the modified value via the
make command line).
Alternatively, setting LD_LIBRARY_PATH may work.
But ideally you should see if there's an official TIFF package for
your distribution and install that.
