[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin manuel.martin at orleans.inra.fr
Thu Feb 13 01:48:08 PST 2014
Hi Ben,
Thanks for the reply. I tried with the band option but it looks like
gdal does not detect the multiple fields as multiple bands :
GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m
 > band=3 output=testclc
WARNING: Raster map <testclc> already exists and will be overwritten
WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
          by GRASS and no parameters found
Projection of input dataset and current location appear to match
ERROR 5:
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m:
GDALDataset::GetRasterBand(3) - Illegal band #
ERROR: Selected band (3) does not exist
Cheers, Manuel
On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
> Hi Manuel,
> GRASS does not support multi-band rasters, so you'll have
> to import each band as a separate raster map.
> r.in.gdal has the "band=" option to specify a band number
> to import.
> Best,
> Ben
> On 12/02/14 17:05, manuel.martin wrote:
>> Hi all,
>> I tried to import an ArcGIS binary raster (corine land cover for the
>> French territory) with three fields on each pixels (VALUE, COUNT and
>> CODE_06) using the *r.in.gdal* command. The import works just fine,
>> except that in the resulting raster, in GRASS, I only get one field,
>> which seems to be the VALUE field (and not the CODE_06 field, which I am
>> interested in, and which is a categorical field, although coded with
>> integers).
>> Is there a way to produce a resulting raster with all the fields of the
>> initial ArcGIS layer, or alternatively to choose one unique field? Also,
>> is there a limitation on categorical fields. For instance, what if
>> instead of integer corine land cover codes I have literal labels, i.e.
>> levels of my categorical field coded with strings?
>> Cheers, Manuel
>> ----------------0----0------
>> INRA - InfoSol
>> Centre de recherche d'Orléans
>> 2163 Avenue de la Pomme de Pin
>> CS 40001 ARDON
>> 45075 ORLEANS Cedex 2
>> tel : (33) (0)2 38 41 48 21
>> fax : (33) (0)2 38 41 78 69
>> http://www.gissol.fr
>> ----0----0------------------
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
INRA - InfoSol
CS 40001 ARDON
