[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin manuel.martin at orleans.inra.fr
Thu Feb 13 02:14:22 PST 2014
I had already tried this (with "2") ;-). No luck either. Reading your
email I tried with "0" (maybe would gdal detect only two bands over
three). It comes out that only "band=1" works....
GRASS 7.0.svn (lambert93):~ > r.in.gdal --o
input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m
band=0 output=testclc
WARNING: Raster map <testclc> already exists and will be overwritten
WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
          by GRASS and no parameters found
Projection of input dataset and current location appear to match
ERROR 5:
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m:
GDALDataset::GetRasterBand(0) - Illegal band #
ERROR: Selected band (0) does not exist
On 02/13/2014 10:59 AM, Benjamin Ducke wrote:
> Hmm, the manual page does not say so explicitely,
> but maybe band numbering starts with "0"?
> In that case your band 3 would have index number "2".
> Ben
> On 13/02/14 10:48, manuel.martin wrote:
>> Hi Ben,
>> Thanks for the reply. I tried with the band option but it looks like
>> gdal does not detect the multiple fields as multiple bands :
>> GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
>>> band=3 output=testclc
>> ERROR 5:
>> GDALDataset::GetRasterBand(3) - Illegal band #
>> ERROR: Selected band (3) does not exist
>> Cheers, Manuel
>> On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
>>> Hi Manuel,
>>> GRASS does not support multi-band rasters, so you'll have
>>> to import each band as a separate raster map.
>>> r.in.gdal has the "band=" option to specify a band number
>>> to import.
>>> Best,
>>> Ben
>>> On 12/02/14 17:05, manuel.martin wrote:
>>>> Hi all,
>>>> I tried to import an ArcGIS binary raster (corine land cover for the
>>>> French territory) with three fields on each pixels (VALUE, COUNT and
>>>> CODE_06) using the *r.in.gdal* command. The import works just fine,
>>>> except that in the resulting raster, in GRASS, I only get one field,
>>>> which seems to be the VALUE field (and not the CODE_06 field, which I am
>>>> interested in, and which is a categorical field, although coded with
>>>> integers).
>>>> Is there a way to produce a resulting raster with all the fields of the
>>>> initial ArcGIS layer, or alternatively to choose one unique field? Also,
>>>> is there a limitation on categorical fields. For instance, what if
>>>> instead of integer corine land cover codes I have literal labels, i.e.
>>>> levels of my categorical field coded with strings?
>>>> Cheers, Manuel
>>>> ----------------0----0------
>>>> INRA - InfoSol
>>>> Centre de recherche d'Orléans
>>>> 2163 Avenue de la Pomme de Pin
>>>> CS 40001 ARDON
>>>> 45075 ORLEANS Cedex 2
>>>> tel : (33) (0)2 38 41 48 21
>>>> fax : (33) (0)2 38 41 78 69
>>>> http://www.gissol.fr
>>>> ----0----0------------------
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
INRA - InfoSol
CS 40001 ARDON
