[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin manuel.martin at orleans.inra.fr
Tue Feb 18 02:43:22 PST 2014
Hi, I just compiled grass r59073 and gave a try.
I could not get the attributes imported along with the raster, but maybe
am I missing something from the new revision of r.in.gdal (although from
the code it looks that the import of values from the attribute table
should be automatic?).
Markus, I just sent you the ESRI layer I am trying to import, in case
you would like to try as well.
Thank you in advance
Manuel
On 02/17/2014 02:48 PM, Markus Metz wrote:
> On Fri, Feb 14, 2014 at 5:41 PM, manuel.martin
> <manuel.martin at orleans.inra.fr> wrote:
>> On 02/14/2014 05:08 PM, Markus Metz wrote:
>>> On Wed, Feb 12, 2014 at 5:05 PM, manuel.martin
>>>> Hi all,
>>>> I tried to import an ArcGIS binary raster (corine land cover for the
>>>> French
>>>> territory) with three fields on each pixels (VALUE, COUNT and CODE_06)
>>>> using
>>>> the r.in.gdal command. The import works just fine, except that in the
>>>> resulting raster, in GRASS, I only get one field, which seems to be the
>>>> VALUE field (and not the CODE_06 field, which I am interested in, and
>>>> which
>>>> is a categorical field, although coded with integers).
>>> r.in.gdal will soon support import of category labels such as those
>>> stored in the CODE_06 field. You can then inspect the labels with
>>> r.category. GDAL supports reading and writing of raster attribute
>>> tables, so far only the color rules stored in a raster attribute table
>>> are imported, but I plan to add import of labels to r.in.gdal. Note
>>> that this applies only to GRASS 7.
>>> Markus M
>> Good to hear that ;-). I will wait for the next release of r.in.gdal
> Done in r59073.
> Markus M
>> (meanwhile I did import clc vector layers with v.in.ogr and later managed
>> the category labels with v.to.rast).
>> All the best,           Manuel
>>>> Is there a way to produce a resulting raster with all the fields of the
>>>> initial ArcGIS layer, or alternatively to choose one unique field? Also,
>>>> is
>>>> there a limitation on categorical fields. For instance, what if instead
>>>> of
>>>> integer corine land cover codes I have literal labels, i.e. levels of my
>>>> categorical field coded with strings?
>>>> Cheers, Manuel
>>>> ----------------0----0------
>>>> INRA - InfoSol
>>>> Centre de recherche d'Orléans
>>>> 2163 Avenue de la Pomme de Pin
>>>> CS 40001 ARDON
>>>> 45075 ORLEANS Cedex 2
>>>> tel : (33) (0)2 38 41 48 21
>>>> fax : (33) (0)2 38 41 78 69
>>>> http://www.gissol.fr
>>>> ----0----0------------------
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> INRA - InfoSol
>> CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
