[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin
manuel.martin at orleans.inra.fr
Tue Feb 18 04:14:40 PST 2014
On 02/18/2014 12:47 PM, Markus Metz wrote:
> On Tue, Feb 18, 2014 at 11:43 AM, manuel.martin
> <manuel.martin at orleans.inra.fr> wrote:
>> Hi, I just compiled grass r59073 and gave a try.
>> I could not get the attributes imported along with the raster, but maybe am
>> I missing something from the new revision of r.in.gdal (although from the
>> code it looks that the import of values from the attribute table should be
>> automatic?).
> Yes, r.in.gdal automatically imports whatever it finds as color tables
> or attribute labels.
>> Markus, I just sent you the ESRI layer I am trying to import, in case you
>> would like to try as well.
> GDAL does not see an attribute table in the data you sent to me, thus
> GRASS can not import any attributes. If there is really an attribute
> table, it is not recognized by GDAL.
Then maybe this is a gdal problem : I'm saying this because through the
command gdalinfo, it looks like gdal detects an attribute table (see
below).
Cheers
GRASS 7.0.svn (lambert93):~/tmp > gdalinfo
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4
Driver: AIG/Arc/Info Binary Grid
Files:
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4.aux.xml
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/hdr.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/dblbnd.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001x.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/sta.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/vat.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/log
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/prj.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/metadata.xml
Size is 2504, 2089
Coordinate System is:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6019"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4019"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",44],
PARAMETER["standard_parallel_2",49],
PARAMETER["latitude_of_origin",46.5],
PARAMETER["central_meridian",3],
PARAMETER["false_easting",700000],
PARAMETER["false_northing",6600000],
UNIT["METERS",1]]
Origin = (198837.500000000000000,6808087.500000000000000)
Pixel Size = (50.000000000000000,-50.000000000000000)
Corner Coordinates:
Upper Left ( 198837.500, 6808087.500) ( 3d45' 3.55"W, 48d10'48.77"N)
Lower Left ( 198837.500, 6703637.500) ( 3d37'59.07"W, 47d14'36.54"N)
Upper Right ( 324037.500, 6808087.500) ( 2d 4'11.49"W, 48d15'52.06"N)
Lower Right ( 324037.500, 6703637.500) ( 1d58'52.06"W, 47d19'34.69"N)
Center ( 261437.500, 6755862.500) ( 2d51'32.26"W, 47d45'23.95"N)
Band 1 Block=256x16 Type=Byte, ColorInterp=Undefined
Description = test_lf4
Min=1.000 Max=6.000
NoData Value=255
<GDALRasterAttributeTable>
<FieldDefn index="0">
<Name>VALUE</Name>
<Type>0</Type>
<Usage>5</Usage>
</FieldDefn>
<FieldDefn index="1">
<Name>COUNT</Name>
<Type>0</Type>
<Usage>1</Usage>
</FieldDefn>
<FieldDefn index="2">
<Name>CLASS_NAME</Name>
<Type>2</Type>
<Usage>0</Usage>
</FieldDefn>
<Row index="0">
<F>1</F>
<F>1313166</F>
<F>Valleys</F>
</Row>
<Row index="1">
<F>2</F>
<F>79933</F>
<F>Lower Slopes</F>
</Row>
<Row index="2">
<F>3</F>
<F>110782</F>
<F>Gentle Slopes</F>
</Row>
<Row index="3">
<F>4</F>
<F>42435</F>
<F>Steep Slopes</F>
</Row>
<Row index="4">
<F>5</F>
<F>69408</F>
<F>Upper Slopes</F>
</Row>
<Row index="5">
<F>6</F>
<F>1341719</F>
<F>Ridges</F>
</Row>
</GDALRasterAttributeTable>
> Markus M
>> Thank you in advance
>> Manuel
>> On 02/17/2014 02:48 PM, Markus Metz wrote:
>>> On Fri, Feb 14, 2014 at 5:41 PM, manuel.martin
>>>> On 02/14/2014 05:08 PM, Markus Metz wrote:
>>>>> On Wed, Feb 12, 2014 at 5:05 PM, manuel.martin
>>>>>> Hi all,
>>>>>> I tried to import an ArcGIS binary raster (corine land cover for the
>>>>>> French
>>>>>> territory) with three fields on each pixels (VALUE, COUNT and CODE_06)
>>>>>> using
>>>>>> the r.in.gdal command. The import works just fine, except that in the
>>>>>> resulting raster, in GRASS, I only get one field, which seems to be the
>>>>>> VALUE field (and not the CODE_06 field, which I am interested in, and
>>>>>> which
>>>>>> is a categorical field, although coded with integers).
>>>>> r.in.gdal will soon support import of category labels such as those
>>>>> stored in the CODE_06 field. You can then inspect the labels with
>>>>> r.category. GDAL supports reading and writing of raster attribute
>>>>> tables, so far only the color rules stored in a raster attribute table
>>>>> are imported, but I plan to add import of labels to r.in.gdal. Note
>>>>> that this applies only to GRASS 7.
>>>>> Markus M
>>>> Good to hear that ;-). I will wait for the next release of r.in.gdal
>>> Done in r59073.
>>> Markus M
>>>> (meanwhile I did import clc vector layers with v.in.ogr and later managed
>>>> the category labels with v.to.rast).
>>>> All the best, Manuel
>>>>>> Is there a way to produce a resulting raster with all the fields of the
>>>>>> initial ArcGIS layer, or alternatively to choose one unique field?
>>>>>> Also,
>>>>>> is
>>>>>> there a limitation on categorical fields. For instance, what if instead
>>>>>> of
>>>>>> integer corine land cover codes I have literal labels, i.e. levels of
>>>>>> my
>>>>>> categorical field coded with strings?
>>>>>> Cheers, Manuel
>>>>>> ----------------0----0------
>>>>>> INRA - InfoSol
>>>>>> Centre de recherche d'Orléans
>>>>>> 2163 Avenue de la Pomme de Pin
>>>>>> CS 40001 ARDON
>>>>>> 45075 ORLEANS Cedex 2
>>>>>> tel : (33) (0)2 38 41 48 21
>>>>>> fax : (33) (0)2 38 41 78 69
>>>>>> http://www.gissol.fr
>>>>>> ----0----0------------------
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> grass-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> INRA - InfoSol
>>>> CS 40001 ARDON
>> INRA - InfoSol
>> CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
