[GRASS-user] Hydrological grass question: main channel length for each subbasin
Michel Wortmann wortmann at pik-potsdam.de
Tue Feb 18 08:40:24 PST 2014
Thank you for your answers Helmut, Rich and Tom,
Tom: this is indeed a smart way of doing it and I have associated each
main channel pixel to a subbasin ID, but counting the cells and
multiplying that by the resolution seems a bit simplistic or would you
disagree with that? I have now done this with consideration for those
cells draining diagonally (using the drainage). Still leaves some
subbasins that for some reasons have more than one inlet and thus
several branches which then overestimates the length.
Rich: I didnt want to dig that deep into the other code, but yes, that
is definitely an advantage of open source software.
Helmut: the R.basin is what I was looking at but for multiple subbasins
you will end up looping over them.
Cheers,
Michel
On 02/17/2014 08:20 PM, Thomas Adams wrote:
> Michel,
> If it were me, I'd go ahead and take the hit with the brute force
> method. However, I was involved with a project in calculating basin
> average precipitation in real-time, over many basins (~700) for many
> time periods, several times per day. Each second was critical; what we
> did was to convert the real values to ints as cat values and associate
> them to basin IDs; then convert back to reals -- this was very fast (I
> can provide shell scripting). I understand this is not want you want,
> but you may be able to do something analogously, by converting the
> stream main channel pixels to the same cat value and count them (as
> they are associated with each basin), then multiply by the pixel
> resolution -- if you follow what I'm suggesting... Doing what we did,
> did not involve any looping -- which would have been disasterously
> slow for our application.
> Tom
> On Monday, February 17, 2014, Rich Shepard <rshepard at appl-ecosys.com
> <mailto:rshepard at appl-ecosys.com>> wrote:
>     On Mon, 17 Feb 2014, Michel Wortmann wrote:
>         this is what I meant by looping over each subbasin, but that
>         is exactly
>         what I would like to avoid as it would take a lot of time for
>         1000+
>         subbasins and I dont really need all the other analysis.
>     Michel,
>       If you look at the code for that module you'll see that you
>     cannot get
>     directly to the end without calculating all the intermediate
>     values; one
>     attribute builds on those calculated before it. As long as the
>     intermediates
>     are being calculated there's no reason to not put their results in the
>     overall table.
>       If you want only main channel length for 1000+ subbasins you
>     might figure
>     out a way to calculate that directly and modify the code (with a
>     different
>     module name, of course) to do that. This is one of the advantages
>     of open
>     source software licensed under the GPL.
>     Rich
>     Richard B. Shepard, Ph.D.          |      Have knowledge, will travel.
>     Applied Ecosystem Services, Inc.   |
>     <http://www.appl-ecosys.com>     Voice: 503-667-4517      Fax:
>     503-667-8863
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org
>     http://lists.osgeo.org/mailman/listinfo/grass-user
> Thomas E Adams, III
> 718 McBurney Drive
> Lebanon, OH 45036
> 1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140218/02690668/attachment-0001.html>
