[GRASS-user] broken d.mon
Dave Roberts
dvrbts at ecology.msu.montana.edu
Sun Feb 23 14:47:55 PST 2014
Ultimately had to recompile GRASS-6.4.3 to get d.mon to work again. The
make generated numerous errors, but much to my surprise make install
worked and solved my problem (at least for now).
Dave
On 02/21/2014 02:08 PM, Vaclav Petras wrote:
> On Fri, Feb 21, 2014 at 4:06 PM, Dave Roberts
> <dvrbts at ecology.msu.montana.edu <mailto:dvrbts at ecology.msu.montana.edu>>
> wrote:
> Hi Vaclav,
> Happy to stay on list. I'm grateful for all the help I've
> received here.
> So, the problem is not with compilation. GRASS64 was working
> well on my system (except for v.dissolve and lib gmath, see other
> list issues). Oddly, when I mistakenly entered d.mon wx0 it not
> only didn't work (which should be expected), it disabled all the
> other monitor options (seemingly permanently). When I changed to
> another location the problem persisted which really surprised me.
> I'm not sure if I'm able to help more. One more thing. What do you have
> in `$HOME/.grassrc6`?
> I have:
> GISDBASE: /.../grassdata
> LOCATION_NAME: nc_spm_08
> MAPSET: PERMANENT
> MONITOR: x0
> GRASS_GUI: wxpython
> Fortunately I have other machines to work on, but this is my
> primary machine for a large research project that emphasized GRASS.
> I'm in the process of moving to GRASS7, but I couldn't get it to
> compile on this machine (Markus N is helping me with that), so I
> stayed with GRASS64.
> Thanks, Dave
> On 02/21/2014 01:52 PM, Vaclav Petras wrote:
> Hi Dave,
> let's keep the conversation on list. I hope you don't mind.
> On Fri, Feb 21, 2014 at 2:57 PM, Dave Roberts
> <dvrbts at ecology.msu.montana.__edu
> <mailto:dvrbts at ecology.msu.__montana.edu
> <mailto:dvrbts at ecology.msu.montana.edu>>>
> wrote:
> Hi Vaclav,
> Thanks for your help. I'm running Scientific Linux 6
> (EL6-based). when I enter d.mon x0 it says there is no
> such monitor.
> Isn't there some problem with compilation? I'm not sure if this
> is even
> possible but maybe compilation can be set in the way that no
> monitors
> are included.
> The command
> d.mon -l
> generates
> no known monitors
> Hm, now I understand what you are saying, -l behavior differs
> for 6 and 7.
> http://grass.osgeo.org/__grass64/manuals/d.mon.html
> <http://grass.osgeo.org/grass64/manuals/d.mon.html>
> http://grass.osgeo.org/__grass70/manuals/d.mon.html
> <http://grass.osgeo.org/grass70/manuals/d.mon.html>
> So, no x0-9, no png, no nothing.
> Thanks, Dave
> On 02/21/2014 10:56 AM, Vaclav Petras wrote:
> What happens if you write
> d.mon x0
> Note that X monitors does not work on MS Windows.
> On Fri, Feb 21, 2014 at 12:17 PM, Dave Roberts
> <dvrbts at ecology.msu.montana.____edu
> <mailto:dvrbts at ecology.msu.>__m__ontana.edu <http://montana.edu>
> <mailto:dvrbts at ecology.msu.montana.edu>>>>
> wrote:
> Hi Martin,
> Thanks. I do understand that. But now I have
> no X
> monitors
> (nor png or anything else for that matter).
> Dave
> On 02/21/2014 09:18 AM, Martin Landa wrote:
> Hi,
> 2014-02-21 17:10 GMT+01:00 Dave
> Roberts<dvrbts at ecology.msu.__m____ontana.edu
> <http://m__ontana.edu>
> <mailto:dvrbts at ecology.msu.montana.edu>>>>:
> d.mon wx0
> in GRASS64. It not only did not display,
> now no
> monitors
> exist, i.e.
> this is not possible in G6. Here d.mon works with
> X-based monitors,
> ie. d.mon x0.
> Martin
> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~______~~~~~~~~~~~~~~~~~~~~~~~~~~__~~__~~__~~~~~~~~~~~~
> David W. Roberts
> office
> 406-994-4548 <tel:406-994-4548> <tel:406-994-4548
> <tel:406-994-4548>> <tel:406-994-4548 <tel:406-994-4548>
> <tel:406-994-4548 <tel:406-994-4548>>>
> Professor and Head
> FAX
> 406-994-3190 <tel:406-994-3190> <tel:406-994-3190
> <tel:406-994-3190>> <tel:406-994-3190 <tel:406-994-3190>
> <tel:406-994-3190 <tel:406-994-3190>>>
> Department of Ecology email
> droberts at montana.edu <mailto:droberts at montana.edu>
> <mailto:droberts at montana.edu <mailto:droberts at montana.edu>>
> <mailto:droberts at montana.edu> <mailto:droberts at montana.edu
> <mailto:droberts at montana.edu>>>
> Montana State University
> Bozeman, MT 59717-3460
> _____________________________________________________
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> <mailto:grass-user at lists.__osgeo.org
> <mailto:grass-user at lists.osgeo.org>>
> <mailto:grass-user at lists.>__osg__eo.org <http://osgeo.org>
> <mailto:grass-user at lists.osgeo.org>>>
> http://lists.osgeo.org/______mailman/listinfo/grass-user
> <http://lists.osgeo.org/____mailman/listinfo/grass-user>
> <http://lists.osgeo.org/__mailman/listinfo/grass-user>>
> <http://lists.osgeo.org/mailman/listinfo/grass-user>>>
> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~____~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~__~~~~~~~~~~~~
> David W. Roberts office
> <tel:406-994-4548>>
> Professor and Head FAX
> <tel:406-994-3190>>
> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts at montana.edu
