[GRASS-user] Tessellation of a set of polygons
Thomas Leduc thomas.leduc at cerma.archi.fr
Tue Feb 25 08:54:58 PST 2014
Dear GRASS-users & developpers,
As summed up below, I've tried to tessellate the enclosed datasource (a
shapefile composed of several building footprints) using 2 different
approaches:
g.remove vect=buildings,plots rast=buildings_r,plots_r
v.in.ogr -o dsn=/tmp/buildings.shp output=buildings
1st method:
v.voronoi -a --overwrite input=buildings output=vor smoothness=0.15
v.out.ogr --overwrite input=vor type=area dsn=/tmp/src olayer=vor layer=1
format=ESRI_Shapefile
2nd method:
g.region vect=buildings nsres=0.25 ewres=0.25
v.to.rast --overwrite input=buildings output=buildings_r use=attr
attrcolumn=gid
r.grow --overwrite input=buildings_r output=plots_r metric=euclidean
radius=4800
r.to.vect --o input=plots_r output=plots type=area
v.out.ogr --o input=plots type=area dsn=/tmp/src olayer=plots layer=1
As may be observed with the screenshot, (both) output results does not
match expectations.
Do you have any idea of the reason why it's wrong?
Many thanks for your help,
Thomas
[image: Inline image 1]
On Tue, Sep 10, 2013 at 3:10 PM, Thomas Leduc
<thomas.leduc at cerma.archi.fr>wrote:
> Dear Markus,
> Impressive responsiveness. Thanks for the dedicated development.
> http://trac.osgeo.org/grass/changeset/57621 is fully operative on the
> given dataset.
> It took me some time to test it, because I'm a complete newby with GRASS
> community. Just to keep it written somewhere, I first had to checkout,
> configure, compile, and install GRASS7 snapshot on my Debian 6.0.7:
>     svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
>     cd ./grass7_trunk
>     ./configure --enable-64bit
> -with-freetype-includes=/usr/include/freetype2
> --prefix=/usr/local/misc/grass7-snapshot --with-sqlite
>     make
>     make install
> Then, in the GRASS console, I've copied and pasted the following
> instructions:
>     g.remove vect=buildings,vor
>   v.in.ogr -o dsn=/tmp/src/src.shp output=buildings
>   v.voronoi -a --overwrite input=buildings output=vor segment=0.15
> layer=1 format=ESRI_Shapefile
> Many thanks once again.
> Thomas
> On Sun, Sep 8, 2013 at 7:49 PM, Markus Metz <markus.metz.giswork at gmail.com
> > wrote:
>> On Thu, Aug 29, 2013 at 5:38 PM, Thomas Leduc
>> <thomas.leduc at cerma.archi.fr> wrote:
>> > Let's consider a set of input polygons (represented by dark gray
>> polygonal
>> > footprints in the enclosed screenshot [1]). I wonder whether there
>> already
>> > exists a (set of) GRASS instructions to produce the "surrounding
>> > tessellation". I mean, could you please tell me how to compute the set
>> of
>> > multicolor polygons in the enclosed screenshot?
>> > As an example, the blue polygon is the set of points that are:
>> >   - overlayed by the dark gray polygon labeled #1
>> >   - or closer to the dark gray polygon labeled #1 than to any other
>> input
>> > polygon.
>> I have added tessellation of areas to v.voronoi in trunk r57621. You
>> need to use the new -a flag and can control the smoothness of the
>> output with the new segment option. With your example, segment=0.15
>> produces reasonably smooth output.
>> This implementation ignores shared boundaries (not present in your
>> example) which would need to be patched in afterwards. An alternative
>> would be to use v.overlay to obtain areas outside the original input
>> areas.
>> HTH,
>> Markus M
>> > Thanks a lot for any help/advice.
>> > Thomas Leduc
>> > PS: I'm aware there already exist in GRASS some functions such as
>> > "v.to.rast, r.grow.distance, and r.contour" which could help in
>> building map
>> > of distances, and isocontours... I'm also aware there already exist
>> > "v.to.rast, r.thin, and r.to.vect feature=line" to build some sort of
>> medial
>> > axis transform or skeleton.
>> > PPS: input data set
>> > create table b(gid int, the_geom GEOMETRY(POLYGON, 2D));
>> > insert into b values (0, GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0
>> 10, 0
>> > 0))'));
>> > insert into b values (1, GeomFromText('POLYGON ((30 0, 30 -30, 10 -30,
>> 10
>> > -40, 40 -40, 40 0, 30 0))'));
>> > insert into b values (2, GeomFromText('POLYGON ((20 20, 100 20, 100 40,
>> 60
>> > 40, 60 30, 40 30, 40 60, 20 60, 20 20))'));
>> > insert into b values (3, GeomFromText('POLYGON ((60 10, 60 -20, 100
>> -10, 100
>> > 10, 60 10))'));
>> > insert into b values (4, GeomFromText('POLYGON ((-10 -10, -10 -40, -40
>> -40,
>> > -40 -20, -60 -20, -60 0, -50 0, -50 -10, -10 -10))'));
>> > insert into b values (5, GeomFromText('POLYGON ((-40 20, -40 40, -10
>> 40, -10
>> > 30, -20 20, -40 20))'));
>> > [1] this screenshot of about 11 KB is also downloadable at
>> > https://dl.dropboxusercontent.com/u/8846569/tessellation.png
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Thomas LEDUC
Thomas LEDUC
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140225/7296e1d8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140225/7296e1d8/attachment-0001.png>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140225/7296e1d8/attachment-0001.zip>
