[GRASS-user] help with temporal modules
Veronica Andreo veroandreo at gmail.com
Fri Feb 28 07:37:51 PST 2014
Dear grass-users,
HI! This is my first time writing to the list. I'm really interested in
using the temporal modules for some spatio-temporal analysis of MODIS Cl-a
mapped L3 product, but i can't even run the example in t.create manual page
[0]. I'm using GRASS 7 (r59147, re-compiled yesterday) under Fedora 19.
I'd like to know which are the steps I should follow to start working with
these modules??? Do I need to install some extra package or library???
Here's what I've tried and the messages I got:
GRASS 7.0.svn (ll_wgs84):~ > t.connect -d
Default driver / database set to:
driver: sqlite
database: /home/veroandreo/grassdata//ll_wgs84/PERMANENT/tgis/sqlite.db
GRASS 7.0.svn (ll_wgs84):~ > t.connect -p
driver:sqlite
database:/home/veroandreo/grassdata//ll_wgs84/PERMANENT/tgis/sqlite.db
GRASS 7.0.svn (ll_wgs84):~ > MAPS="map_1 map_2 map_3 map_4 map_5 map_6
map_7"
GRASS 7.0.svn (ll_wgs84):~ > for map in ${MAPS} ; do
>     r.mapcalc --o expr="${map} = rand(0, 10)"
>     echo ${map} >> map_list.txt
> done
.... it creates the maps, of course, but then...
GRASS 7.0.svn (ll_wgs84):~ > t.create type=strds temporaltype=absolute
output=precipitation_daily title="Daily precipitation" description="Test
dataset with daily precipitation"
ERROR: Unable to receiving temporal database metadata.
Current temporal database info:
DBMI interface:..... sqlite3
Temporal database:..
GRASS 7.0.svn (ll_wgs84):~ > t.register -i type=rast
input=precipitation_daily file=map_list.txt start=2012-08-20 increment="1
days"
GRASS 7.0.svn (ll_wgs84):~ > t.info type=strds input=precipitation_daily
I've noticed there are 2 slashes in
"/home/veroandreo/grassdata*//*ll_wgs84/PERMANENT/tgis/sqlite.db"
--> tried changing that by defining it with t.connect, but when i run the
example gain, I got the same messages as before...
What am I doing wrong? or what am I lacking here??? Would you please help
me???
THANKS A LOT IN ADVANCE!
And sorry for making (surely) a very silly question :P
Vero
[0] http://grass.osgeo.org/grass70/manuals/keywords.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140228/5181c52b/attachment.html>
