[GRASS-user] compositing rasters
Dave Roberts dvrbts at ecology.msu.montana.edu
Wed Jan 1 08:32:13 PST 2014
Friends,
    I did get an off-list solution (thanks Jiao) that works for two
rasters but not for n (using the implied else).
    I think what GRASS needs is an r.update routine that works like an
SQL update statement, i.e.
r.update map=composite.map value=1 where="map a = 1"
r.update map=composite.map value=2 where="map b = 1"
etc
     This would solve my immediate problem but also have general
utility.  I can export the grids and do it in FORTRAN easily enough, but
I haven't cracked the GRASS API yet to actually make a GRASS function
out of it.
Maybe there already is such a thing?
Thanks, Dave
On 12/31/2013 06:00 PM, Dave Roberts wrote:
> Colleagues,
>     I know this must be easy, but I haven't found it.
>     Suppose I have three grids (a, b, and c) where each grid is 0 or 1,
> and the 1s are mutually exclusive.  I want a new grid where if grid
> a=1 then newgrid = 1; if grid b=1 then new grid = 2; if grid c=1 then
> newgrid = 3.
>      Something like  r.mapcalc "new=if(a,1) || if(b,2) || if(c,3)"
> seems like it ought to work but I can't seem to use multiple input file
> that way.
> Thanks in advance for any help, Dave
David W. Roberts                                     office 406-994-4548
Professor and Head                                      FAX 406-994-3190
Department of Ecology                         email droberts at montana.edu
Montana State University
Bozeman, MT 59717-3460
